I want to activate my i phone cause i changed networks
Model 5098s Alcatel ,I am on 2g network,I have tried to change to 4g but it just would'nt change ,checked apn, data sim ,network ,rest network still would'nt work,how can I activate 4g.
you have not mentioned a country but some places have closed down the 2 g network and the 2 g phone is not manufactured to work on 4g
Mar 25, 2017 | Alcatel Cell Phones
My Samsung GT-C3520 has been displaying emergency calls only for some time. I know it is not a network issue as other family members on the same network have good reception. Any suggestions?
Yep it is no longer activated. You need to contact the carrier to get activated on there network. Messing with sim cards and set up options can cause this problem.
Mar 03, 2015 | Samsung Cell Phones
Cant activate my samsung galaxy s4 mini with us cellular
US Cellular is a CDMA network. Maybe your Galaxy S4 is for a GSM network? GSM phones have a SIM cards and these need to be changed to activate them on another GSM network as well as the GSM phone being unlocked to do this. In USA only T- Mobile & AT & T run GSM networks. Outside of USA most networks are GSM. There are four GSM frequency bands which vary in use by country. The S4 if it is a GSM phone, being an high level phone would be a quad band phone, so it will work anywhere. Cheaper phones may only have Dual Band and therefore only work in the countries with the matching frequency bands.
Dec 31, 2013 | Motorola Mobility RAZR V3
Activation will not go through. No wifi networks around here, so how do I connect to the Internet?
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Nov 10, 2012 | LG Optimus V Vm670
My network is inactive
First Option:
Secend Option:
Oct 02, 2012 | RIM BlackBerry Storm 9530 Smartphone
I have a new bb 8830 world edition phone on a Vodafone GSM network. I have requested for the bb service to be activated. Which the service provder has. Unfortunately, the settings are not received by my BB...
Looks like you just change your original sim card with other network sim card. You must unlock your blackberry first before you can using other network in your phone. What you need is blackberry 8830 unlock code from your original phone network sim card. You can get blackberry unlock code from network provider or buy from third party sites which have lower cost rather than network provider.
May 14, 2011 | RIM BlackBerry ® 8830 Cellular Phone
My daughter quit adding minutes to her phone and it has lapsed
Depending on you network, you should be able to buy minutes, then load them onto the phone directly.
If you can't do that, you'll have to all the customer service number for your carrier and ask them to activate the phone again. (This might cause your number to change)
Apr 05, 2009 | LG ALLTEL AX145 Cellular Phone
My N95 Nokia keeps telling me No services as soon as i got to USA. Pls wat can i do...Thanks
Try contacting your network provider and ask if Roaming is activated with you. If not, then tell them to activate it. Then you may have to wait a while or it could activate straight away.
Also try turning you're phone off and on.
Jan 31, 2009 | Nokia N95 Cellular Phone
Mms settings
Hello you two. the problem might be your networks and not the phones cause the motorola w375 comes mms enabled all that will be left for you to do is to activate mms from your network. all you have to do is call your netwrok and ask them to activate it for you. and if they say they did do this the other way round. instead of changing it to sms confiugre your mms.Under Message Setup > MMS Message Setup there is an Autosignature field. How on earth can I set a signature for regular SMS? I don't use MMS so that feature is basically useless to me. Is there anyway to get it in SMS? i hope i helped bye!
Sep 11, 2007 | Motorola Mobility W375 Cellular Phone
 Grubhead
Grubhead
