Washing machine does not start cycling
When i start the program the only thing i can see on the sceen is just the indication of locked door.After i wait and i hear a little noise for a couple of times from the electonic motherboard...
    Top Expert:
  • 21,873 Answers
This is the car and truck section. You may want to repost this in the washer section along with the brand and model number.
Posted on Feb 14, 2014
4 Suggested Answers
NJFIRESTORM
  • 84 Answers
SOURCE: 2003 ford futura programming a new keypad
Adding and Removing remote Keypads to the Smartlock module
Up to four Keypads can be programmed and used with the Smartlock Remote
Central locking system.
If you have replaced the BEM, or new keypads are being added to the
system, you will need to train the keypad codes to the module.
# 1. The ignition switch should be in the Off position, with all the
doors shut and Unlocked.
# 2. Turn the ignition key to the ACCESSORY position and within 5
seconds, operates the rear demister switch exactly three times in quick
succession. (IE. Press the switch so the Demister light turns on, then
off, then back on again.)
# 3. After the 5 seconds is up, the door locks will change state, to
indicate that the BEM has entered keypad learn mode.
NOTE : All existing keypads at this point, have been erased from memory
# 4. Press either buttons on the keypad that is to be trained. The door
locks will change state twice, to indicate that the keypad has been
added to the BEM memory.
# 5. Follow step 4. for each keypad that is to be added to the BEM
memory. A maximum of 4 keypads can be added to the BEM memory.NOTE :
You must teach all remote keypads for the Smartlock module, before
proceeding.
# 6. When you have taught all the remote keypads, turn the ignition to
the Off position to leave the learn mode. The door locks will change
state to indicate a return to normal mode.
# 7. Check the function of both buttons on each keypad, to ensure that
the keypad has been trained.
Posted on Sep 15, 2008
autotherapis
  • 501 Answers
SOURCE: 2000 Astro van - drivers window only goes up a in increments
The motor is shot. It works a little and overheats, replace the motor . Same thing the the lock acuators. The are trying but have lost the power to move the locks. May as well replace them while the door is apart.
Posted on Aug 16, 2009
rickyrt441
  • 4399 Answers
SOURCE: 1999 Jeep Grand Cherokee Laredo
Thanks for choosing FixYa and welcome. If you have a vehicle that will turn over and over but will not start, I will tell you some things that you need to check. Every vehicle needs air, fuel, and fire to start. Now, the first thing you want to check is the fuel system. You want to make sure that the engine is getting fuel. The easiest way to test the fuel system is by testing the fuel pressure on the fuel rail. You need to refer to your owner manual for the correct measurement of pressure. Another easy test is using starter fluid. If it starts when you spray the fluid, you have a fuel issue. If it doesn't, check the ignition system. If your pressure is not correct or you have no way of testing the fuel pressure, start by checking your fuel pump. The fuel pump pumps fuel out of the gas tank and to your fuel filter. When you first turn your key on, you should be able to hear the fuel pump kick on for a second or two. It makes a soft buzzing sound. Listen for this sound. This will determine if the pump is kicking on and working. If you don't hear this sound, check your fuel pump fuse, relay, and your reset button. Not all vehicles have a reset button, so once again check to see if you have this button. If you change all of these and the pump still doesn't work, you may have a bad fuel pump. Test and make sure the pump is getting power before you change it. Now, you want to make sure the fuel filter is not stopped up. Check the gas lines and make sure they have no damage. Lastly, make sure fuel is getting to the fuel injectors. If you are getting fuel, you will need to make sure you are getting fire. You need to test your spark plugs or coils for spark. If you have spark, you should look over your timing belt or timing chain to make sure it is not broken or slipping. If you are not getting spark, you will need to check the spark plugs, coils, coil packs, wires, distributor, distributor cap, and rotor. Anyone of these can cause a vehicle to not spark. Check everything you can. Make sure the rotor is spinning and make sure the distributor cap has all metal contacts. Also, make sure the cap is not damaged or cracked. Make sure none of the plug/coil wires are damaged. Make sure they are all hooked up correctly. Now, it is possible that you could have a bad camshaft sensor or crankshaft sensor. In some vehicles, the camshaft sensor is built into the distributor. You want to test each of these parts and make sure each one is getting power. If a part is not getting power, that may be the reason your vehicle is not starting. If you have a check engine light on, you need to get your computer scanned for error codes. More then likely, if your vehicle won't start, your check engine light is on. The light is on because your computer has detected a problem with the vehicle. You can buy a cheap code reader for around forty dollars from Autozone or Advanced. Just make sure you know all your codes for your vehicle. When you have it scanned, the computer may know the exact parts you need to change. Most of these parts listed run off your ECM. The ignition system is a very complex system. It is rarely, but they do go bad. If you believe that the computer is to blame, make sure you have it flashed before you put it in your vehicle. If you don't, it will not work. Finding your error codes is the best way to finding your solution. If not, you will have many things to check. Always make sure you run a test on a part before changing it. Make sure that part is getting power. If it is not, check the power source. I know this is a lot of information, but any of the parts listed can cause the vehicle to not start. If you have no access to a code reader, fuel pressure tester, or a code reader, you can still check a lot of things. It is just harder. Remember, always use the process of elimination. Determine if the part is working or not and move on to the next part. You will eventually find your problem. Lastly, electrical problems can cause the symptoms you are having. They are very hard to find. When trying to find an electrical problem, you need to make sure you know what to test for. Each wire has a purpose. One part of the engine can shut down another part. You need to know how many volts you are testing for on each wire. You can use a voltage meter to test for current. I hope this helps you and thank you for reading. Thanks for using FixYa and best of luck
Posted on Apr 28, 2011
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
How to fix door on Samsung Washer model wf210anw. It makes 3 very hard clicks prior to starting.
Has the sound changed? The door lock assemble can be loud and sound like its faulty. If the washer completes cycles, then door lock is working correctly. One thing to check is the strike on the door. Look for anything that is odd or doesn't look right. A damaged strike can create extra noise. Good luck!
Jan 29, 2016 | Samsung WF210ANW 3.5 Cu. Ft. White Front...
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
My indesit washer wia111 starts to wash but once it has done the main wash and goes to rinse the machine stops working and the red door lock indicator goes off
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into and run the program to finally drain shut off and open lock. . If this does not happen then the voltage at the valves,motor and pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 26, 2011 | Washing Machines
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
