Question about Sanyo Proxtrax Multiverse Projector Plc-xp41 Lcd Home Theater Video Multimedia
How to restore pin code for sanyo projector
I have forget my pin code for my projector
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
Codes connect comcast remote
I forget pin code. How above reset pin in3924 (infocus)
Aug 23, 2013 | InFocus Office Equipment & Supplies
Plz tell me the pin and puk code for x201
i forget ma nokia x2 01 pun code ma imei number is 358277/04/553977/4 please help me
Sep 14, 2012 | Office Equipment & Supplies
I am trying to locate the S/N on my Sanyo PLC-XU88. How can I find it?
Hi
It should be on the back or underside of projector.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Sanyo PLC-XU88 Projector
My sanyo projector is projecting everything in red and the replace lamp light has come on, I have replaced lamp but it is still red.
It was a computer cable problem. One of the pins in the cable had been snapped and this has now been replaced.
Nov 03, 2009 | Sanyo PLC-XU56 Multimedia Projector
How to get tv working on the projector
It depends, check if your TV has Video Line Out (yellow pin) jack at rear then hook it in external video source/ input of multimedia projector to watch TV picture through projector.
Thanks.
Sep 22, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XU105 Will shut down in 10 to 15 seconds
YOU HAVE A BAD LAMP OR THE LAMP DRIVER BOARD BAD
Aug 24, 2009 | Televison & Video
How do I change the input from the DVI-I input to the 15
I found the online manual and followed the instructions to set to "auto" input. Everything works fine.
It had been a discouraging ordeal trying to locate a new DVI cable (which came with the projector)
and as it turns out the 15 pin cable works fine. Thank you.
Rick
Jun 11, 2009 | Sanyo PLC XU50 Multimedia Projector
Connecting my pc to a sanyo plc sw30 projector
never mind the usb, u need to only connect the video output ( yellow rcs connector ) to the vido input of the projector & it will work fine!!!
Dec 29, 2008 | Sanyo PLC-SW30 Multimedia Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo Proxtrax Multiverse Projector Plc-xp41 Lcd Home Theater Video Multimedia Logo
15 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
