Question about OKI Electric Industry C8800DN Printer
FATAL ERROR 131 OKI 5700 - OKI Electric Industry C8800DN Printer
Soulvisitor
  • 1113 Answers
SOURCE: oki c5200 "Fatal Error 106"
from your service manual....main board issue
Posted on Jan 16, 2008
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
SOURCE: OKi C5800ldn 231: fatal error 03
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Posted on Jul 27, 2010
aviral_srms
  • 1216 Answers
SOURCE: How do I reset fatal
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Posted on Jun 18, 2011
OKI c6150 with error msg 002-fatal error. please, I need a quick answer. do not have time to scroll through pages of older posts
If you printer has an additional memory card fitted then remove it (powered off of course) and turn on and see what happens. If the fatal error is still there then with the age of the machine (getting on in years) it is better to replace it as the error refers to the cpu in the control board and that's expensive on older machines to replace.
Jun 20, 2016 | OKI C Office Equipment & Supplies
Oki c7300 Fatal Error
all oki errors are fatal errors, there will be a 3 digit number that will tell what the error actualy is
Jun 02, 2014 | OKI C7300 Led Printer
OKI C830 Error code 131
This is an error for the yellow LED head. Check the connection. If you feel confident enough try moving the LED heads around. If the error moves with the LED head then it needs to be replaced. If the same error occurs the the CU pcb need to be replaced.
Apr 07, 2014 | Oki Electric Industry C830DN Led Printer
How do i fix error 131 on oki printer
Please confirm the model and error code. I have checked the technical manual for the B410d and there is no reference to error 131.
Apr 07, 2014 | Oki Electric Industry B410D Laser 30PPM...
How do i fix a 131 fatal error?
FATAL ERROR 131, 132, 133 OR 134 ON THE DISPLAY ON POWER-UP
CAUSE - ONE OF THE LED PRINT HEADS IS DISCONNECTED
SOLUTION - RECONNECT THE RIBBON CABLE TO THE PRINT HEAD
Just for information, the led print heads are the four assemblies that hang down from the lid of the machine when you open it.
Sometimes they become unclipped, and the ribbon cables can get pulled loose.
131 probably means the front one.
Mar 04, 2011 | Office Equipment & Supplies
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
OKI Electric Industry C8800DN Printer Logo
24 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
