Question about SIB VIA VT6307 3+1-Port IEEE 1394 FireWire PCI Controller Card (885480282487) Serial Adapter
Via vt6307 ieee 1394 driver - SIB VIA VT6307 3+1-Port IEEE 1394 FireWire PCI Controller Card (885480282487) Serial Adapter
I need a driver firewire ieee 1394 for HP Compaq 8710w Mobile Workstation working with Windows 7 Ultimate?
Maybe the Vista driver will work. Most times if there is not one for Windows 7 the previous version will work.
Try Driver Guide
http://www.driverguide.com
Apr 25, 2012 | HP Compaq 8710p NoteBook
I need drivers for this card, OS XP
You can get drivers from www.driversguide.com
Sep 02, 2010 | MSI VIA VT6306 2-Port IEEE 1394 FireWire...
What dose the icons mean on front panel what is the little square hole for next to the mike connection
hello, it is most likely a firewire connection.
FireWire, originally created by Apple and later standardized as IEEE-1394, actually preceded USB and had similar goals. The difference is that IEEE-1394 was originally intended for devices working with lots more data -- things like camcorders, DVD players and digital audio equipment. IEEE-1394 and USB share a number of characteristics and differ in some important ways. Here's a summary:
  • Like USB, IEEE-1394 is a serial bus that uses twisted-pair wiring to move data around.
  • However, while USB is limited to 12 megabits per second, IEEE-1394 currently handles up to 400 megabits per second.
  • USB can handle 127 devices per bus, while IEEE-1394 handles 63.
  • Both USB and IEEE-1394 support the concept of a isochronous device -- a device that needs a certain amount of bandwidth for streaming data. This mode is perfect for streaming audio and video data.
  • Both USB and IEEE-1394 allow you to plug and unplug devices at any time.
hope this helps,
regards
Amar Sondhi
Dec 05, 2009 | Medion M3 Director 5100 PC Desktop
Unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
Oct 24, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
Windows vista won't pickup my jvc mini dv camcorder
try finding a driver from the manufacturer of the device windows vista sometimes can not find drivers for certain stuff
Sep 01, 2009 | SIIG 4 x 4-pin Type A Female IEEE 1394a -...
How to connect IEEE 1394 (4 pin) to computer
IEEE 1394 is commonly referred to as Firewire. Your Dell doesn't support it. You will have to purchase a firewire adapter card and install it and its drivers into your computer.
Apr 22, 2009 | Dell Dimension 2400 PC Desktop
Driver for IEEE 1394 BUS HOST CONTROLLER
Download Driver Detective and it will reinstall it and do updates for you.
Dec 12, 2007 | Toshiba G15-AV501 Qosmio Notebook
Can I use Firewire to transfer video?
Your computer must be equipped with an IEEE 1394 (Firewire) interface and video capture software. Provided you have both of these, follow the directions below. To connect your digital camcorder to your computer using IEEE1394, follow these steps: 1. Connect the IEEE 1394 interface on your camcorder to the IEEE 1394 interface on your computer. 2. Turn on your computer. 3. Turn on your camcorder. 4. Start the video capture software on the computer. Image capture should begin provided the computer hardware and software are configured correctly. If image capture does not begin, you must consult the computer or capture card manufacturer for assistance. Note: If you don't have an IEEE 1394 interface on your computer, you can buy an IEEE 1394 pci card at your local computer store that will work with most current computers.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
SIB VIA VT6307 3+1-Port IEEE 1394 FireWire PCI Controller Card (885480282487) Serial Adapter Logo
346 people viewed this question
Top SIB Computers & Internet Experts
Piyal Perera
Piyal Perera
Bios Pro
Raj Patel
Are you a SIB Computer and Internet Expert? Answer questions, earn points and help others
