Question about Geha Primo 2600 Shredder
Servicing Geha crocodile paper shredder
Start button needs to be rectified
2 Suggested Answers
t_vinson57
  • 58 Answers
SOURCE: order main drive gear for geha paper shredder
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
Geha Primo 1500
every thing is serviceable !
problem here should be is a replacement part available to fix it.
you check with the maker to see if parts are available.
Aug 11, 2014 | Geha Primo 1500 Shredder
Primo 3901 geha
Any mechanical device which has wheels grinding or cutting paper material should be oiled in the shafts holding the cutting wheel. Not in excess, just a few drops to assure an even distribution. Run the device in both directions after oiling. You can get a specialized oil for shredders at any Office depot Store. Hope this is helpful.
Jul 01, 2014 | Office Equipment & Supplies
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
Where can you buy parts for the Geha Primo hs Class 6 shredder?
cooks mobile shredding inc. 3815 watman ave , memphis, tenn. 38118 901-565-8188 email cooksmobileshred@bellsouth.net
May 09, 2010 | Office Equipment & Supplies
Have a level 6, won't shred
Unplug the shredder. When you remove the cover carefully remove the auto start sensors. There is a little pushdown tab.Clean them with a soft cloth. A kleenex will be ok. Re-insert them, making sure they lock in place. Plug the shredder in an see if that solves your problem.
Sep 19, 2008 | Geha Primo 3900 HS Shredder
Shredder won't shred - all paper is cleared - works intermitantly
Run the shredder in "Reverse" mode for 15 seconds.
Oil the cutting head thoroughly as this is a High Security shredder.
Test it at 4-5 sheets.
They always overrate the capacity but if you want to keep it operating, shred 3-5 sheets max.
Running for serveral minutes could be due to dirty optic sensors. Unplug the shredder, remove the top (2 screw underneath front and 2 in back). Remove the sensors (they have a little pushbutton tab) and clean thoroughly with a soft cloth. Re-insert the sensors ensuring they lock in place, reset the top cover and test.
Jun 05, 2008 | Geha Primo 3900 HS Shredder
Order main drive gear for geha paper shredder
Good luck, Tom
Feb 18, 2008 | Geha Primo 2600 Shredder
Geha Primo 2600 Shredder Logo
81 people viewed this question
Top Geha Primo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Geha Primo Office Equipment and Supply Expert? Answer questions, earn points and help others
