Question about Fisher and Paykel Refrigerators
How to defrost fisher and paykel fridge with out the manual
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
woodchuck789
  • 4070 Answers
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 28, 2009
  • 3 Answers
SOURCE: Fisher & Paykel active smart fridge keeps
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Posted on Nov 07, 2009
localwonder
  • 6784 Answers
SOURCE: Noisy, Chattering fan with fisher & paykel fridge.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.....
Posted on Dec 20, 2009
Fisher and paykel n405l fridge freezer .Freezer on top is working but fridge not working
There is a problem in the defrost system. Could be the defrost timer, defrost heater, or defrost safety thermostat.
Jul 14, 2014 | Fisher and Paykel Refrigerators
Frost inside frezzer
Sounds like the automatic defrost is malfunctioning. I would contact the place you bought it from or the manufacturer to see about repair
Dec 23, 2013 | Fisher and Paykel Dishwashers
Fisher and Paykel refrifgerator F02, F07, F17
ok thats a defrost element like in a stove but not as hot its located in behind the paneling in the freezer
Mar 01, 2018 | Fisher and Paykel Refrigerators
Fridge compartment not cooling. Freezer seems OK. Fisher & Paykel - model E522B
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 07, 2011 | Fisher and Paykel Icon E522B Bottom...
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Oct 04, 2009 | Fisher and Paykel Active Smart® E522BR...
THE TOP PART (FRIDGE) IS NOT COOLING
Your defrost system may be out. There are 3 parts, the heaters, t-stat and timer. Hope this helps! :>)!
Aug 14, 2009 | Fisher and Paykel Active Smart E522B...
E372B FISHER & PAYKEL FRIDGE WARM
I'd say you most likely need a new defrost element and evaporator Chassis. You'll most likely find there's a big lump of ice behind the evaporator chassis in the freezer inturn blocking the fridge vent or the defrost element is burnt out icing up te Evaporator. It pays to replace both anyway you'll need to unplug the unit and leave the doors opens for 48hrs to defrost it first. cheers
May 16, 2009 | Fisher Refrigerators
Refrigerators Logo
20 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
