Question about Sony PlayStation 3D display
Sony playstation 3d display black screen
The monitor goes to a black screen for 2secs 3-4 times a hour
  • 8 Answers
SOURCE: sony playstation 3 console
If Im not mistaken, that Acer monitor only has a VGA connection for input. There is no way that Im aware of to have the PS3 output VGA, so I believe the answer is no, you will not be able to. sorry.
Posted on Jun 17, 2008
  • 142 Answers
SOURCE: My Sony VGC-RA826G Desktop turns on and then beeps
Sounds like a memory error. Try pulling out one stick at a time until it is able to boot. Assuming, of course, you have more than one stick. If not, buy or borrow a new stick and try that. With 3 beeps the bad stick is likely to be in DIMM slot 1.
here is a description of beep codes for various BIOSes:
http://pulonangka.web.id/software/beep-codes-error-codes
Posted on Sep 02, 2009
  • 1139 Answers
SOURCE: Does the Playstation 3 support
With the new 3.50 update that Sony released it unlocked the ability for the PS3 to play 3D blu rays. Are you sure you have updated to 3.50 as you will need to do this before playing any 3D blu rays. I am sure if you update to this version you will find everything will be fine.
Hope this helps
Posted on Dec 04, 2010
SOURCE: playstation 3 will not play movie package "Bolt"
Yer I have the same problem, but I have no solution sorry but need help or try ringing sony Australia
Posted on Feb 03, 2011
SOURCE: my playstation 3 will onoly go to a black screen,
he said it goes fuzzu and then the screen goes blanc. I have the same problem its some sort of loose connection and its nothing to do with the lens. Try moving your playstation around it should come back on but only for a while till the connection goes again.
Posted on Oct 01, 2011
Black screen
one of the IC has gone, please check with technician.
Feb 13, 2014 | Sony PlayStation 3D display
Got a playstation display and it has a bluish purple vertical line down the tv but it disappears when any red shows up in thae area of the line any ideas what's wrong with it and if it can be fixe
The display unit is defective, some IC seems to be damaged, it can be repaired from any repair shop, but I don't think the cost will be low, as the display is manufactured by Sony and the spares are not available easily .
Aug 28, 2012 | Sony PlayStation 3D Display - 3D LED...
I can hear but cant see the screen
Go into display settings and go to video output settings and select the type of connector on your tv then just click automatic and that should fix it. You usually need to do this when going from a 3d tv to a normal HD tv. And never call playstation or sony for help.. they are ****.
Jul 05, 2012 | Sony Playstation 3 (PS3) Console
Ps3 only goes to start up screen no further
The actual freezing problem can be caused by the GPU overheating and SO can the no display error as well. For an in depth look at how to fix both of these problems see this > http://www.bestps3repairguides.com/
Mar 12, 2012 | Sony Playstation 3 (PS3) Console
When i load call of duty black ops the screen splits into 2 horizontal screens ......dosent do it with any other games i have
Go to your display settings and instead of choosing automatic for display choose custom. The 3D option is splitting your picture horizontally.
Nov 26, 2010 | Activision Video Game Consoles & Games
Black screen pushing red to green donot work do not hear any beep
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor)....
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
My PS turns on Green light and all, but my television screen is showing only all black. . .what is the problem?
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Playstation is on but screen is black
Jun 30, 2010 | Sony PlayStation 3 40GB System
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
Monitor
Is there still power to the monitor or is the screen just black? Do you hear any sort of sound when it goes black? Does the time the picture goes out vary or does it happen after say "X" minutes/hours everytime? Do you have any power saving software activated that would cause the monitor blank out? Check display properties? Sounds weird but have you checked for any viruses or spyrus nasties? If its hardware it could be many different things. Let me know what happens. Good Luck Tim
Mar 15, 2007 | Sony CPD G420 19" CRT Monitor
Sony PlayStation 3D display Logo
82 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
