Question about Sharp XL-MP130 CD Shelf System
My radio is not swiching off timer - Sharp XL-MP130 CD Shelf System
Why is building entrance light not working?
The timer may be working, but the switch has failed. This is a common failure of electro-mechanical timers.
Mar 10, 2016 | Intermatic T103 Indoor 120-Volt 40-amp...
GE 15135 mech timer turns on fine but pin will not turn it off
Your pin is not adjusted! Open the tumscrew a bit (half a turn!) and adjust the mobile arm to tatch the swich
Jun 08, 2014 | GE 24-Hour Outdoor Mechanical Box Timer,...
How to remove channel swiching tune in radio shack trc 481
thats to let you know that the channel has been changed.
Nov 11, 2013 | Radio Shack Trc-481 Cb Radio
I've had my Mazzer Mini for about 3 years. I grind about 1/2 lb per week. Today I went to grind and when I turned the timer switch nothing happened. Yes it is plugged in. I think it makes a popping...
1 check the supply wire to swich change if it is not ok 2 chek the swich change if it is not ok 3 if it is automatic check microswiches(one where ground coffee comes out and other below doser) clean from coffee upper swich and try. it block sometime from ground coffee 4 check the windings of electromotor give grinder for if it is not ok 5 check condensator change if it is not ok 6 try to spin the burrs by hand, check if they are not blocked. change bearings if it is not ok
if you need to change bearings you need advice how to open the motor.
Jan 05, 2011 | Mazzer Mini Burr Coffee Grinder
Does the TRC-503 CB Radio have a PA
do'se it have a swich for pa if not then no
Jan 03, 2011 | Radio Shack TRC-503 CB Radio
My 87 camry wont star i think is my swich
Have a local mechanic check the main power relay. This feed power from the ignition switch out to the stated accessories
Dec 16, 2008 | 1987 Toyota Camry
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
Aug 19, 2008 | Audio Players & Recorders
Sharp XL-MP130 CD Shelf System Logo
41 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
