Question about Emerson EWF2004 20" TV
My tv screen is black and white
I connected an hd cable box to my tv. I did everything right but my screen is black and white and I can also hear everything. I tried fixing the resolution to 480i but even when its 1080i I get the same result. Did I connect something incorrectly?
    Top Expert:
  • Emerson Master
  • 74,383 Answers
Check the system settings. Enter its menu option, and reset this settings according the color system that your country adopted with both on-air transmission and for video view. Set the system settings to 'Auto', if you're not sure about what to do in this case.
Gopakumar Gopalan Google
Posted on Feb 13, 2014
3 Suggested Answers
  • 108 Answers
SOURCE: cable female adaptor is missing
The small metal box is the tuner. The tuner has to be removed to replace the broken off RF connector. The connector has to be soldered to the tuner housing (metal box) and the leg of the connector has to be soldered to the circuit board, board has to be checked for cracks or if it is broken. If board is damaged the tuner will have to be replaced, if its available.
Posted on Aug 17, 2009
SOURCE: Emerson EWT2721 a/v cable connections won't work
how do i get to input without remote
Posted on Dec 25, 2009
Cannot connect xbox to my JVC HD 56G647
Try using your AV1 connection
You are using your TV remote to select the input source
Regards
Sir Dana Taylor
jdtaylor@live.ca
Apr 23, 2017 | JVC Televison & Video
I just bought a samsung home theater in a box system, model Ht-D5500. And i also have a hd cable box. i was wondering how can i connect my cable box up so that i get audio from the speakers instead of the...
There are two ways of connecting to get cable TV audio from your Home Theater System.
1) If your HD cable box has a digital audio out ( either optical or coaxial ) you can connect this to the Samsung Home Theater Systems digital input. While watching a TV channel scroll through the Samsungs input ( source ) selector till you hear the sound. Remember to mute the TV sound while you are doing this.Most probably it will be the CBL/SAT input or Video AUX.
2) If your HD box does not have digital audio out you can connect the Red & White audio out of the same to your Samsungs Aux or TV or Video audio inputs . Ignore the yellow socket and connect only the Red and White audio inputs.For getting Video through the TV connect the HD box to TV via HDMI cable or connect the Yellow video out to the TV's Yellow video in. I am sure it is already connected .
Mar 21, 2011 | Audio Players & Recorders
My flat screen toshiba has gone black and white. The picture is lovely except no colour. I have sound
If you are connected to an HD cable box or satellite box via component cables, make sure they are firmly seated at each end.
Sep 02, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Dell 32" HD TV flashes black every few minutes
You may want to make sure it's a Yamaha by seeing how the TV displays when connected directly to a cable box or DVD. Also try different HDMI or component inputs to see if it's something in the input connection you're using.
Apr 27, 2017 | Sharp Aquos LC-32D40U Television
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Screen craked broken screen
Is it a Plasma TV? Are you saying the screen is cracked? do you have a top box cable box? Also, make sure you have your TV input set to HDMI if you have an HDMI cable hooked up between your cable box and TV.
Apr 04, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
HD cable question
It sounds like you dont have the right HD box. When connecting HD you will use an HDMI cable or a component cable consisting of 5 cable total 3 for video two for audio. Coax cable is not used to connect HD to your TV / Monitor.
Mar 27, 2008 | Televison & Video
Emerson EWF2004 20" TV Logo
56 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
