Question about Bose Lifestyle 30 System
Bose 20 display failed - Bose Lifestyle 30 System
    Scholar:
  • 21 Answers
Older Bose Lifestyle systems are prone to electrolytic capacitor failures. Replace all electrolytic capacitors on the main control board with identical uF value, equal or greater voltage rating, equal or greater temp rating. There are about a dozen on the board with at 2-3 different values. Disassembly and reassembly is straight forward. Those with capable skills in mechanical and electrical areas should find the project will take about 1-2 hours. I recommend grounding the board when working on it. Find a spot on the board where the ground is marked, and attach a jumper to a ground point. Take caution during the disassembly -- take photos, lots of plastic parts, etc. The eCaps are polarized, so be sure to check polarity as you unsolder, and install new eCaps with same polarity (+ & - ) as the old.
Once caps are replaced the voltage levels to correctly operate the display will be back to factory settings, and the display should show brightly. Good Luck!
Posted on Mar 24, 2014
Display screen led light wont come on
If the display has been gradually fading and is now unreadable, the fault is almost certainly loss of emission of the fluorescent display and it will need a replacement display module fitted (at a Bose Service Centre)
Is there any sign of characters showing in a darkened room?
If it has suddenly gone off, with all other radio features are working as normal, but prior to this the display was bright and clear, and the set has not been subjected to a fall or a sudden sharp impact of some kind, (which can crack the display module and cause it to fail) then the most likely possibilities are; a failed filament supply to the display module, a failed high tension supply rail to the display module, or loss of data feed to the display. It is also possible there may be a fault in the day/night brightness switching circuitry that has shut the display down completely. It is not possible to be more specific without seeing the unit, or even knowing which model it is I'm afraid.
Sep 04, 2014 | Bose Wave Music System CD Shelf System
Tip
Bose LifeStyle 20 Manual Download
Download Bose Lifestyle 20 Audio System Manual
Would you like to review the features of the Bose Lifestyle 20 Audio System?
Have you lost your Bose Lifestyle 20 Audio System Owners Manual?
Would you like a digital, searchable, pdf version of the Bose Lifestyle 20 Audio System Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bose Lifestyle 20 Audio System documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Audio Players & Recorders
Tip
Bose Lifestyle 20 Manual Download
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle 20 System
Bose SoundTouch 20 won't connect to internet radio --> 1029 error
Hello, i had the same Problem.
Remove the Soundtouch App from your PC and reset Bose Soundtouch ( press 1 and Volume - ) install Soundtouch App new, follow the instructions and let the default settings.
Do Change not Network Name Bose Soundtouch...
Skip Music Libary from iTunes or Windows Media.
Dec 25, 2013 | BoseĀ® CORPORATION Bose - SoundTouch 20...
Bose Lifestyle 20 very Dim display
There are instructions available at www.AnyoneCanFixIt.com that has detailed pictures of this repair, step by step.
Jun 23, 2009 | Bose Lifestyle 20 System
Display not working
I think there are some solutions available from www.AnyoneCanFixIt.com for the Bose Lifestyle 20 series with the display issue.
May 26, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle sound system shows "Failed 801"
your hard drive is about to fail or has failed.
If you can still play music from stored area and If you want to keep your songs thats stored on system, turn off at power point and take to bose auth repairer, they should be able to transfer songs across to new hard drive.
I have same problem, this is a common problem with bose.... not good for how much they are. Hard drive is left of cd tray, on its side.
hope this helps :)
Mar 29, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Bose lifestyle fault code 802
Here's what the Bose support website suggests.  Good Luck!
Messages displayed during a Music Information Update
Messages may appear on your media center display during a Music Information Update. If you see a message with instructions to call Bose, and a three-digit code such as "Error Code 802" or "Failed 172" while performing a Music Information Update, it does not necessarily mean there's something wrong with the system. Performing a media center reset and installing the update again may address the issue.
To reset your media center, follow these steps:
  1. Turn the media center off. Wait two minutes
  2. Unplug the power cord from the media center. Wait 30 seconds
  3. Reconnect the power cord
  4. Wait until "Bose Lifestyle" disappears from the screen
Note: After a reset, you will need to wait several minutes before playing stored music (3 to 20 minutes, depending on how many CDs have been stored). All other sources will be available immediately after the system powers up.
If you have any additional questions about these messages, please contactBose® Technical Support or call 1-800-278-1281.
Dec 01, 2008 | Audio Players & Recorders
Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Dec 22, 2007 | Bose Lifestyle 38 System
Life style error codes 801 & 802
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Nov 18, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 30 System Logo
183 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
