Imation multi media 2.5: hard disk 250 gb
I have imation multi media player model is mention above. its working very good. but now problem is this new file are hd file like mp4. but my device media player is not play these format, mkv, hd mp4, etc. ist possible to update new version of media player on my imation multi media 2.5" hard disk. please tell me with hopefully thanks, Fayyaz Rizvi from Pakistan
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Hi. What is needed is a codec pack upgrade. Here is Imation's support page. They also have a phone number you can call: https://support.imation.com/app/home Good Luck
Posted on Feb 13, 2014
SOURCE: Portable hard disk corrupted
try chkdsk /f <drive>
Posted on Aug 31, 2008
  • 69 Answers
SOURCE: WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Posted on Mar 25, 2009
SOURCE: Unable to access external WD 500 Gb drive: "You need to format the disk"
I have battled this for a few days. Your mentioning USB leads me to a possible solution.
I had a 500GB drive and put it in the USB enclosure and could only see 128GB one time, 138GB another. I found that external drive enclosures have their own IDE controller chips with older ones limiting the size of the drive they are able to "see".
The best test is to internally mount the drive (perverts will read this differently than intended and risk injury due to shock!) to make sure it can be seen. If so then the next best step is to spring for a new drive enclosure, one that supports the higher capacity drive. It worked for me! My old external enclosure's IDE controller could not handle the higher capacity drive and the new one was perfectly happy with it. Good luck! - Andy C
Posted on Apr 09, 2009
efs_perpends
  • 1996 Answers
SOURCE: Local disk error WD My Passport 250GB
Do you connect & disconnect the drive according to WD's recommendations here? Try another cable. (If yours was wearing out, that might explain why it only connected some times.) Try another usb port. Check the power supply (another receptacle) Unplug other usb devices from the system.
See this article. Good luck!
Posted on Aug 18, 2009
siawolf
  • 749 Answers
SOURCE: Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Posted on Aug 09, 2010
Testimonial: "The advice was very helpful."
Imation HDD Pro Media player 500 gb. orange light flashing but not detected by my laptop.
You "killed" it -- either the USB-to-disk-drive adapter inside the case, or the disk-drive inside the case.
Remove the disk-drive from the case, and install it in a replacement case (with replacement power-supply).
May 09, 2015 | Imation Computers & Internet
Imation apollo 2.5 portable HDD 250 GB driver missing?
Just download it from Imation.com. Install it and your on your way.
Feb 16, 2014 | Imation Apollo (27223) 250 GB USB Hard...
I need to install the driver information to a new computer for the Imation Apollo Pro UX external hard drive
What operating system are you using? There is usually no need for drivers on external HDD. The computer usually recognizes it and installs the necessary software for it.. Let me know if this answers your question and good luck..
Sep 09, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Describe your Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Problem
Please repost your problem, and enter a description of your problem in the textbox where it says "Describe your Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Problem"
Aug 25, 2011 | Imation Apollo UX 2.5" USB Portable (250...
My "imation apollo 25-PHDD
You need data reovery help. This guy does it remotely and works from donations. FreeDataRecovery.us
Jul 13, 2011 | Imation Apollo (27223) 250 GB USB Hard...
It stoped reading, suddenly, it stil switches on the blue led light, but doesn't regognize anymore in anycomputer, what can i do?
The USB control board inside is probably faulty. The internal hard disk will still probably be working but it will need to be removed from the enclosure. You can purchase a suitable new enclosure or USB-to-Hard drive converter from Maplin or the internet (e.g. e-bay).
Feb 18, 2011 | Imation Apollo (27223) 250 GB USB Hard...
My 2.5 Imation Portble (Model # Apollo 25 PHDD - 160 GB) is not working. The laptop, PC nothing is reading it. The blue light comes...but thats it. I had taken a hard disk to take care of data that i would...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 06, 2010 | Imation Apollo (27223) 250 GB USB Hard...
WD HD Media player damaged my hard drive??
Hi Dear! This problem could be solved through a software. You should use Western Digital Disk Manager, your WD hard disk will work properly after using that your WD hard disk pass all test of the software. When it will pass all test it will work properly and in other condition if it will not pass then you should try again so that the software will fix the error and it will made workable.
Thank You
Jul 24, 2009 | Western Digital My Book Premium ES...
Which is better laptop deal?
Hi !!
Ofcourse 2.4 ghz is better than 2.1 ghz but its not a very big difference if price difference is more than 100$ than go for first one else second one is good and the most important thing i want to mention is that it all depends upon your needs you havent mention for what purpose you are going to purchase. But both are enough for gaming, daily use and for techie as well.
Hope that helps
Thanks
Jul 10, 2009 | Computers & Internet
Why can'tm I play DVD+R DL/2,2x 8 Hr discs on my SharpDV-RW 250x Recorder
Does your player support the disk type you have???
Minus disks are different to Plus disks in respect to the machines they will work in and the formats you put them on to the disk my only be read by the machine the writes them
Looks like your disk type could be a mismatch,
Check them and let me know thanks
Jul 21, 2008 | Imation 16575 2.4x DVD+RW Storage Media
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
