Washing machine panasonic NAF70B3 model - 1st rinse water level is very little
I noticed after 1st wash with detergent, there is very little water (one mug) for the 1st rinse then it spin again but for the last rinse the water will go up to the correct level covering the clothes . 1) May i know why there is so little water for the 1st rinse? my previous panasonic unit - for both rinse the water level always cover the clothes.
  • 38 Answers
SOURCE: Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
Posted on Jul 24, 2007
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
  • 27 Answers
SOURCE: Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Posted on Sep 23, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Posted on Feb 27, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
My washer wont rinse or spin and when its finished washing it gets to rinse cycle and beeps and error code e4 comes up i emptied clothes and it still wont work
No make or model came through with your question... so the FIRST GUESS... is ... THIS IS A NEW RELATIONSHIP with a "HE" (HIGH EFFIEIENCY) washing machine.
You can CONTAMINATE your machine quite badly by not using THE RECOMMENDED "HE" rated detergents... & CLEANERS.
These new machines will rapidly deteriorate in performance... if the APPROPRIATE (HE) detergents ARE NOT USED.
Sensors sample the detergent/dirt in the water to enable the wash cycle to adjust wash time & water levels...
By NOT FOLLOWING the INSTRUCTIONS you are risking PERMANANT DAMAGE to these sensors...
Read your OWNERS MANUAL... There-in (I believe you will find
HE cleaners (not cheap) are recommended to ATTEMPT to restore performance...
Else you are looking at an EXPENSIVE SERVICE CALL on a NEW MACHINE.. Who knows... MAYBE it will be covered under your WARRANTY... Stranger things have happened (these days).
Good luck with that.
affresh WASHER CLEANER 3 Tablet Odor Remover Clean ANY Washing Machine...
Amazon co uk washing machine cleaner
Jul 16, 2016 | Washing Machines
The problem with my top loder panasonic washing machine is clothes dont come out clean.the liquid detergevt that i use does not always dissolve during wash and asa result clothes stiil soapyz.there are...
If you have the user's manual for this machine, check to see that you are using the recommended detergent and the correct quantity of detergent. Some machines will actually fail mechanically from using the wrong type of detergent (such as using standard detergent in a high-efdficiency washer). The pH (softness/hardness) of your water also determines how thoroughly the detergent dissolves and rinses from clothes.
Panasonic (
Q2. Why are there black stains on clothes after washing?
A2.May be your washing machine is dirty due to the residual accumulated through times and need to be overhauled. The possibility is that, a build up caused by interaction of fabric softener and detergent which can flake off from washing machine tub and stains the clothes. Try to dilute and dissolve the softener before putting it into the machine to reduce such black stains.
Spotting can also be a reaction between detergent and fabric softener, a leaking washing machine transmission, or excessive deposits of detergent or fabric softener in the tub flaking off during the wash cycle.
Good luck from Detroit, MI, USA.
Mar 01, 2011 | Washing Machines
Hi, I've got a hotpoint WF000G which wont rinse properly on a fast wash, still soap suds on the clothing and have to put it on a full rinse cycle to get rid of them. Have tried clearing the filter (which...
Use very little detergent (HE) on a fast wash, about half the amount you usually do and set the machine to heavy instead of nomal, if yours has the settings for water level.The heavy setting uses more water. If your model does not have the normal/heavy settings, wash only very small loads on the fast cycle so that there is more water for the cycle. Also, be sure you are rinsing in cold, since cold water dispurses suds. You should also be sure that your rubber seal is very clean. I use a cloth and plain hot water and clean the seal weekly. It can build up alot of detergent residue as well as mold, etc.
Dec 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate Care II top loader washing - rinse issues
New concentrated powdered detergent takes very warm water to break it down. As for most dark clothes use cold water. I have one of these top loaders and for my cold wash colored clothes I use a liquid detergent and have no problem.
May 06, 2010 | Whirlpool LSQ8000 Top Load Washer
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
Not getting clothes clean
Try using less detergent and putting white vinegar in the rinse water. You can pour 1/4 C. or a little more into the automatic fabric softener dispenser for the final rinse, or put it in by hand.
Nov 23, 2008 | Roper RAS6233KQ Top Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Detergent doesn't seem to rinse out
common problem you may need to remove the spin bowl and clean them they get lint build up around the top hope this helps.
Mar 03, 2008 | Maytag Performa PAV2200
Washing Machines Logo
Top Washing Machines Experts
