Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
The streamer on my x1 has stopped working, the machine produces coffee but no stream is coming out when the stream button is switched on
  • jennifer woo Dec 09, 2007
    I have the same problem with my steamer. I cleaned it and water comes through with no problems. It also steamed with the cleaner solution. I then tried to use it a couple of hours later and it started to steam and then nothing came out.
Several things I would check here. How old is your machine? Is the coffee coming out hot enough? If not, then perhaps the boiler is not reaching optimum working temperatures and needs replacing. When did you last descale your unit? If you live somewhere where there is a lot of hard water, and you don't prefilter it, then it could be scale build up in the tube. Try soaking only the tube end of the wand in some vinegar for about an hour, then try flushing it with steam once again. Finally, one has to be dilligent in CLEANING the steam spout right after you use it, EACH AND EVERY TIME! (that is why you almost always see barristas with a damp cloth over their shoulder, ready to use). Milk left on the wand will bake on and become quite hard to remove. This will happen on the outside as well as inside the tube. Soak the end of the tube with boiling hot water for about 10 minutes, wipe the end clean, and with a fine wire or pin clean the inside of the steam wand tube. You may have to repeat this procedure several times to fully clean the wand. If you are at all mechcanical, you could take your machine apart, remove the wand, and soak/clean it separately. But only do this if you are a quite confident handy person. Hope this helps and good luck!
Posted on Nov 03, 2007
Hi, I had exactly the same problem with my X1. I used a pin to unblock the steam wand and then descaled it and it worked again fine. Thanks
Posted on Feb 04, 2008
Ground Coffee Kit/Holder
There were two versions of the Francis Francis X1; one without the logo (older) and one with. I guess your only chance is ebay; but why would someone sell the holder without the machine?
May 27, 2014 | FrancisFrancis! X1 Espresso Machine
No steam
You may have a clog in one of the hoses. Otherwise pump may be clogged. Or faulty heater. Is it hot?
Aug 28, 2009 | FrancisFrancis! X1 Espresso Machine
X1, aluminium: no water filtering through
It is possible that the coffee screen area is blocked, since the steam and hot water work? Try removing the screen and cleaning.
Aug 03, 2009 | FrancisFrancis! X1 Espresso Machine
Francis X1 overheat quickly
hey. you have calcium build up on the wands that go in your boiler so they can't messure the temp properly so it keeps heating.buy a decalcifier from any coffee site online or coffee machine sales and repaires place.
Dec 14, 2008 | FrancisFrancis! X1 - Stainless Steel...
Steam wand not working
The coffee brews fine but the steam wand is not working.
Pressure build ok.
Dec 09, 2007 | FrancisFrancis! X1 Espresso Machine
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
480 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
