Question about Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
Spread toner on paper - Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
  • Konica Minolta Master
  • 6,161 Answers
What do you mean spread toner
Posted on Jan 18, 2016
The left side of paper comes out of my Dell 1320c printer very faint. Why?
If there is a toner cartridge in this printer, take it out and shake it. Do this outdoors in the event that come toner comes out in the process. Don't want to soil carpeting with toner! Sometimes the toner clumps up and doesn't spread throughout the cartridge. Shaking it, distributes the toner and allows printing more evenly.
Jan 08, 2015 | Dell 1320c Laser Printer
There is a black line down one side of the paper. how do you get rid of that?
Your problem may be either a bad drum or fuser unit. Look at the drum and check for any scratches or toner there. Check the fuser unit for a black ring on it that may deposit toner onyour paper. Be careful as the fuser unit is quite hot! Also make sure the inside of the printer is clean. Y ou may vacuum it out. Caution! Don't blow it out with canned air. You'll just spread any toner all inside the printer.
Feb 18, 2011 | Brother HL-2170W Laser Printer
It prints out a document with the center looking faded and spread with toner.
Is the spread toner fixed on paper or not? If it is, open the left door of the machine and see if the drum have dirt on its center. There is possibility that there is paper fiber on the cleaning blade of the drum.
If the toner is not fixed, probably the fixing film of your machine is torn on its center portion.
Nov 03, 2010 | Canon iR 2016i Black and White Copier
HP Colour Laserjet 2840 - all toner spread out when printing
Replace the toner cart. immediately
Take printer outside and blast with air from small low-pressure compressor.
Toner is very messy, but harmless
Mar 27, 2009 | HP LaserJet 2840 Printer
Hp 2300m
Replace your toner cartridge first. If the problem persist replace the fuser.
Feb 18, 2009 | HP LaserJet 2300L Printer
Canon Pixma 470/ cyan and yellow won't print
it may be many things, here some thing to try:
the ink or toner is contrammed with foreign liqued like oils, water, bad ink, bad toner cartridge,
oil, water, ink toner inside the ink itself
oil from a human skin my have came in contact with refill of ink or toner cartridge, cleaning solvent to clean the cartridge, needles for hte ink or toner cartridge, water in the ink or toner cartridge, steam or vapors of some kind, compress air can or air compressor will spread water solution, the freon is used in compressed air can thats way they get so cold when you spray the can.
paper may also be wet some how try new and different brand of paper.
rod the candymangandy
Feb 04, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
Change the developer in afficio 450
To remove the Dev. unit.
1. Open the right upper cover and front cover.
2. PCU. (☛ 3.11.1)
NOTE: Spread paper on a clean flat surface that is free of pins, paper clips,
staples, screws or any other metal objects.
3. Loosen [A] (! x1)
4. Rotate bracket [B] left.
5. Development unit [C]
NOTE: Pull slowly to avoid scratching or nicking the development roller.
6. Set the development unit on the spread paper.
7. If you are temporarily installing a used development unit for test purposes,
perform SP2-220 and 2-802-1 after installation (☛ Chapter 5, “Service Tables)
Replacing the Dev. material.
1. Development unit (☛ 3.12.1)
2. Remove the development roller (☛ 3.12.3)
3. Empty toner [A]
4. Turn drive gear [B] to ensure that no developer remains in the unit or on the
developer roller.
NOTE: Dispose of the used developer in accordance with local regulations.
Work carefully to avoid scratching or nicking the development roller.
5. Pour approximately 1/3 of the developer [C] evenly along the length of the
development unit.
6. Rotate the drive gear [D] to work the developer into the unit. Repeat [C] and [D]
until all toner is in the unit and level with the edges.
7. Reassemble the development unit
8. Cover the toner entrance hole [A] with a piece of paper.
9. Install the development unit in the machine.
10. Turn on the main power switch, make sure that the machine has warmed up,
then perform the TD sensor initial setting using SP 2-801.
NOTE: When performing this setting, cover the toner entrance hole with a
piece of paper. This prevents used toner falling from the PCU into the
development unit during the TD sensor initial setting and interfering
with the Vref setting (toner density reference voltage).
11. After performing the TD sensor initial setting, remove the sheet [A] from the development unit.
This is how you replace and reset (calibrate) the new Dev. material.
Jan 20, 2009 | Office Equipment & Supplies
Smudges along the right side of the paper
Hi Scottmortona,
Welcome to FixYa!
I encountered this while printing my lecture notes for my students. This seems either a drum issue or the toner.
  1. Take out the toner.
  2. Ensure that the toner is evenly spread out by holding it horizontally, and tilt forward and backward.
  3. We need to ensure the toner is even.
  4. Take out the drum unit.
  5. Check are there any toner powder stuck on the sides of the drum?
  6. If so, use a soft brush and slowly brush off the toner stuck there.
  7. At the top of the drum, there is a blue notch. Slide this a few times to do a wire cleaning.
  8. Place the toner into the drum
  9. Place drum into printer now.
  10. Try printing a few pages.
Let us know if you have any problems.
Thank you for rating us.
Jan 05, 2009 | Brother HL 5250DN Laser Printer
Ricoh nrg mp 1600 Aficio copier/scanner/printer
MP 1600L copier/printer produces print-outs with small toner dots spread over the paper. How can I solve this problem?
Nov 07, 2008 | Ricoh Aficio 250 Copier
Print paper
Not much,in most cases both can be switched, thermal is different, lasers use toner not ink, Premium inkjet paper has better ink asorbition properties with little spread, and paper designed for lasers can cope with the heat applied when it passes via the 180 deg fuser that melts the toner to it. Generally paper used in inkjets and laser is just standard 80gsm paper
Never use labels/transparentcy's designed for inkjets in laser machines they wont cope with the heat,
Jan 30, 2008 | Nikon COOLPRINT Thermal Printer
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
