Question about RCA Universal Remote Control
Have a sanyo tv a sunkey rcb501 box and a rc5011s remote control
When I hook all of them together, I can get the remote to come on and it says "boot" then goes to 4 dashes. The tv is set to channel 4 and it will change to a clear screen. I don't know how to do anything from that point on. I do not have any directions for anything but the tv. Looks like I need a lot of help.
SOURCE: need code for direct tv remote
ALL CVODES FOR DIRECTV RC23 REMOTE
Posted on Mar 13, 2008
  • 74 Answers
SOURCE: program my new rcr remote.
Your RCA codes and instructions are at this RCA link:
http://www.thompsontv.com/rcarc.html
Posted on Mar 27, 2008
dauphine
  • 207 Answers
SOURCE: universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Posted on Apr 10, 2008
SOURCE: RCA-4 RCR 450 Universal Remote- Need Codes for Sanyo T.V
Here is the page to find RCA Remote codes
http://remotefinder.rca.com/default.aspx?site=rca
Posted on May 14, 2008
SOURCE: Need to know "HOW TO" set up RCR312W
You have to hold the component button (TV) and enter the code from http://www.rca.com/codefinder. The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
Posted on Aug 22, 2009
Phone number for Sunkey in USA
https://www.facebook.com/pages/Sunkey-Corporation-De-OrlandoFlorida-USA/113979685284535
Sep 02, 2015 | Televison & Video
Program Sunkey Universal Remote
To get more details about the setup procedure to RCA remote control, check the sites linked here. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | RCA Universal Remote Control
Universal Remote from Hell
You may have to use a different universal remote control. All universal remote controls do not contain all possible codes.
Dec 08, 2017 | Televison & Video
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
I have a sunkey electronics converter box and i need the code to program it into my philips univerrsal remote
I have a sunkey converter box as well but an RCA remote and I can't find the code anywhere
Oct 17, 2011 | Televison & Video
I need tv tuning codes for sanyo c25eg95b
Read the Instruction Manual for the Universal Remote Control it should have an Auto Tune feature where you can set the code by pointing the control at the TV when on and pressing the POWER ON and SET button on the control together for 3 seconds, when the TV turns off press the TV button immediately, Good Luck
May 17, 2010 | Sanyo Televison & Video
Hooking up digital satellite system to sanyo 27'
if you can't operate the receiver from the front then there is something wrong with it. you need to get it repaired or replaced.
May 05, 2008 | Sanyo DS27510 27" TV
Sanyo mts stereo tv purchase in 1998
Must have original remote with Sanyo. Go online for search to Sanyo customer support
Dec 24, 2007 | Sanyo DS32920 32" TV
Televison & Video Logo
214 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
