Question about JVC TH-A10 System
Will not play any DVD or CD
I opened up the unit, thinking that there would be a huge ball of dust over the laser or something,  but everything looked rather clean.  When I insert a CD or DVD, it starts to spin, and then ejects the disk.  I could see the laser (red light) being emitted, so it looks like that is working as well.
I tried using a lens cleaner, but the little brushes are at the edge of the disk, and I noticed that the head really only travels from the inner centre to about half the radius.  i.e.  it never reaches the outer edge...
Any idea as to what may be happening?
BTW   Before it stopped completely running any disks, it started being selective about which disks it would play.
Thanks!
  • 156 Answers
REPLCE THE LASER PICKUP UNIT AND CHECK
Posted on Oct 27, 2007
SOURCE:
I have an elderly JVC dvd player; the videos appeared broken up, even the sound was in- consistant. i changed the batteries in the remote and tried several different DVDs, but no improvement.
Try either using a DVD/CD laser cleaning disc or if you are able to, open the case and manually clean the laser lens with a cotton swab. It may only be a dusty/dirty laser. If you choose to open up the DVD player, give all the internals a dust off with a clean household paint brush and a vacuum cleaner (*use care on both the laser lens and internals of the player to avoid damaging it). If this does not solve the corrupted image and audio, the laser may be at the end of it's life and the unit will need replacing.
Here's an example of a DVD/CD player laser cleaning disc so you know what to look for -
Cleaning DVD CD Disc Lens Cleaner Kit WII XBOX PS4 Disc Player Dust Dirt...
Oct 11, 2018 | JVC Televison & Video
Dust Seal ripped
That is going to be a dealer item...also what is a ball holder...I don't think that is what it's called...It's not a huge deal if that dust cover is torn.
Mar 12, 2014 | Acura Integra Cars & Trucks
Richo 2045 paper misfed in C. I HAVE CHANGE THE PHOTOSENCOR AND THE PROBLEM STILL EXIST
i think you were cleaning the machine so when cleaning these type of machines you must be very careful.Okay you must change laser unit and don't blow these machines when cleaning because once the dust goes to laser unit it gives you a code/paper misfed so try to change laser unit
Sep 14, 2011 | Ricoh Aficio 2027 All-In-One Laser Printer
Not taking paper. like something is stuck inside
the rollers that grab the paper often get slick from dust , use a cotton ball and rubbing alcohol and clean them,
May 12, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
Feb 01, 2010 | Toshiba E-Studio 3511 Color Copier
Disc reading error
the laser cant read the disc either the disc dirty or scratch or the laser has dust or hair on it get can of duster and blow it in there then try if that dont work you will need to open it and clean the laser off with a cotton ball or q tip and while it is open just go ahead and blow some duster around in it to clean it to help prevent any other problems.
Nov 12, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
Dvd drive cannot read cds and vcds but can read dvds only
I had the inverse problem on my unit - 7 months after I bought it brand new it wouldn't read DVD's, but would read CD's no problem -- I bought a replacement loader from LG, swopped them out myself and now works 100%.
Turned out the laser for reading DVD's had gone - they use different lasers or wavelengths or something... :)
Jan 09, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Trackman wheel....ball fell loose, now actin weird
Dust has a tendancy to collect under the ball at the 3 contact tips (you should look under the ball)and it is possible enough dust collected when the ball was removed, that the dust particles became a large dust ball and lodged under the ball making it impossible to move!
Remove the ball and clean the area and replace the ball and it should work fine.
Aug 29, 2008 | Logitech Cordless TrackMan Wheel...
Poor quality print
Dear This problem shows that there is a dust in you "laser sccaning unit". Clean the mirrors of laser assembly (Only experience person can do it means mechanic of printer). Please covered your printed with cloth or vice versa. Do not leave open and protect it from dust.
Sep 20, 2007 | Brother HL-2070N Laser Printer
JVC TH-A10 System Logo
153 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
