Question about Glory GFR-V20
Error 1204 Screen displays err: 1204 sensor ps5l check the sensor and press the c key
  • 343 Answers
PSL stands for "position sensor-left". Check the left sensor for dust or some obstruction on that sensor. The operators manual will show you where that sensor is.
Posted on Jan 02, 2015
Cannon 2002n E355-0005 error
Hi
Please follow the below procedure to enter Service Mode
1. In standby mode, press the "Settings/Registration" key.
2. Press the "Reset" key.
3. Press the "Back" key.
4. Press the "Settings / Registration" key.
5. The service mode screen is displayed.
Use the "Back" key to exit Service Mode
COPIER> FUNCTION> CLEAR> ERR; and then turn OFF and then ON the power.
Still have an error after following that steps, please call at 1800-204-4427. I can solve you out.
Dec 17, 2016 | Cannon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202
Canon iR2202
Hi
Jul 24, 2015 | Canon Office Equipment & Supplies
How to reset canon printer ir 2320L
I'm not faliliar with this model as I only work on American sold models but I'm sure the following may help. I'm also assuming you have an error code and turning off and then back on the power didn't help. Try resetting the error code by going into service mode: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. You should be in service mode. If not press the reset key serveral times to make sure everything is reset and try getting into service mode again. Press the " COPIER " button on the display and the screen changes. Press the " FUNCTION " key across the top of the display and then " CLEAR " then " ERR " and finally " OK ." You have cleared the error out of the copiers memory. Turn off the copier waits a few seconds then power back on. Hopefully this gets you in the right direction.
Aug 15, 2012 | Canon imageRUNNER 5000 Copier
ERROR CODE e000001-00010
Thsi is an error code dealing with temperature of the fuser assembly. . Try resetting the error code by going into service mode: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. You should be in service mode. If not press the reset key serveral times to make sure everything is reset and try getting into service mode again. Press the " COPIER " button on the display and the screen changes. Press the " FUNCTION " key across the top of the display and then " CLEAR " then " ERR " and finally " OK ." You have cleared the error out of the copiers memory. Turn off the copier waits a few seconds then power back on. If the error comes back then you have to have the fuser assembly either rebuilt or totally replaced. Good Luck.
Jul 31, 2012 | Canon imageRUNNER 5000 Copier
My cannon iR3320 displays error code E000002-0000. the problem started today after yesterday's power surge
Most likely an error reset will take care of the problem. Get into service mode by pressing the additional function key, 2 & 8 key at the same time, then additional function key again. Press copier, function ( at top of display ), CLEAR, ERR then OK. Power down and back up again the copier. If error continues then the fixing film assembly will have to be replaced.
Dec 08, 2010 | Canon imageRUNNER 2200
System error for cannon 1670f
Press the usermode star-the star just above the lcd display-and then # key,scroll with the arrows until clear is displayed press ok and scroll again untill ERR is displayed press ok,Swotch the machine off and on again.
Jun 30, 2009 | Canon ImageRUNNER 1670F Copier
Canon IR 400
i have canon ir405 cpier it dispays error code E243 please help me sir
Jun 01, 2009 | Office Equipment & Supplies
Error code E00012-002
If I recall correctly, e12 is a jam code. Power the unit off and look in user serviceable areas for paper bits. inspect sensors for paper bits. reseat external finisher unit. power back on. you may have a bad paper sensor in the unit.
Feb 19, 2009 | Canon imageRUNNER 2200
001 error occur
error for faulty temp sensor we can try to clear 1st if it comes back you need to have the thermister changed..... inthis order press add func key / then 2 & 8 key at same time / then add function key again . ( you mayneed to do this acouple times) screen should change to serv mode then in this order touch copier / function / clear / err / ok turn off copier then turn on good lick
Jan 01, 2009 | Canon imageRUNNER 5000 Copier
Glory GFR-V20 Logo
623 people viewed this question
Top Glory Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Glory Retail Supply Expert? Answer questions, earn points and help others
