Question about Seiko Coutura Watches
7t62 alarm hands wont move - Coutura Seiko Watches
I cant set the arm time
[PDF]The Apple Watch User Guide (PDF)
https://manuals.info.apple.com/.../apple_watch_user_guide.pd...
Apple Inc.If you have difficulty seeing the Apple Watch or iPhone screen to set it up, .... Note: If you disable your passcode, you can't use Apple Pay on Apple Watch. ..... Alarm • Timer • Stopwatch • Battery charge • World Clock • Your monogram (displays ...
[PDF]Cal. 7T62 - Seiko
www.seikowatches.com/support/ib/pdf/SEIKO_7T62.pdf
SeikoYou are now the proud owner of a SEIKO Analogue Quartz Watch Cal. .... into consideration the time required to set the ALARM hands and to adjust the .... The single-time alarm cannot be set for a time more than 12 hours ahead of the current ...
How to Set an Alarm on the Apple Watch - YouTube
Dec 26, 2015 | Watches
Seiko 7T62 Crown not coming out
try unscrewing it first then pull out
Dec 09, 2012 | Seiko SNA553 Alarm Chronograph
When I pull out the crown to the second place, the alarm time does not match the watch set time. How can I correct this?
Imbahe,
Here is the procedure to make the alarm time match the you you have set for the main watch time:
2. ALARM HAND ADJUSTMENT
Hour hand Minute hand
B
ALARM
hour hand ALARM minute hand
B Press repeatedly to set ALARM
hands to the time indicated by the
main time hands.
? Set the ALARM hands to the time the main
time hands indicate.
* The ALARM hands move quickly if
button B is kept pressed.
Then press the crown all the way in when finsihed.
Your watch is caliber 7T62. You may download a complete settings instruction manual for this caliber here:
http://www.seikowatches.com/support/ib/index.html
The instructions you need are on page 3 of the manual. I hope this will fix your problem with the adjustments. If you need more help, please let me know.
Regards, Bill
Sep 16, 2010 | Seiko Coutura SNA341 Wrist Watch
I need a manual for a Pulsar watch calibur #7T62
Pulsar are made by Seiko and support can be obtained from their web site. (The number your quoted is a Seiko number- all Pulsar models seem to start with two or three letters).
Put "www.seiko.co.uk/support/instructionbooklets" into you search engine and you should come to the Seiko instructions list. Scroll down to find your watch and download the instructions.
Mar 06, 2010 | Seiko Pulsar watch
Seiko 7t62 Coutura Black Ion; alarm resets NOT to current time but to about 3 hours later?! Yes, I have RTFM ;-)
Click on my profile, then click on TIPS AND TRICKS. There you will find link for all Seiko watch manuals. Download yours and learn how to reset the alarm. Rate me, plz.
Feb 20, 2010 | Seiko Coutura Chronograph Watch
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
I have a seiko chronograph sports 150 watch; had the battery changed a few day ago and just noticed that the second hand & stopwatch hands are not 'centered'. is ther a way to reset this ? cheers
As jimmyguru said.
1. Pull the crown to the second position (all the way out)
2. Push and hold the reset button and allow the chronograph hand to rotate near the 12 o'clock position.
3. Release the reset button.
4. Repeatedly push and release the reset button to find tune the hand position until it is right at 12 o'clock.
5. Push the crown back in.
Nov 05, 2009 | Seiko SNA553 Alarm Chronograph
Seiko watch mechanism replacement
nice day to you! your watch is need of general cleaning and recondition ,efter cleaned and condition the machin ! be sure that the case back gasket is good and apply a small amount of silicon greas to avoid water damage ! close it verry tight ! good luck !god bless !
Sep 02, 2008 | Seiko Watches
Watches Logo
16 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
