Question about Seagull Scientific Systems Seagull-Scientific BarTender Enterprise RFID 7.75 Barcode Label Software - P/N BT-RE30 Enterprise License
Bartender barcode activation - Seagull Scientific Systems Seagull-Scientific BarTender Enterprise RFID 7.75 Barcode Label Software - P/N BT-RE30 Enterprise License
Activation key for bartender
It has a 1 month free trial and after that you have to pay. Go to
http://www.bartenderbarcodesoftware.com/label-software
for an activation key
Feb 02, 2014 | Seagull Scientific Systems BarTender...
Code activation
only the manufacturer can help you with any codes associated with their program
Oct 21, 2013 | Seagull Scientific Systems BarTender...
Code activation
Contact software manufacturer or distributor and they will assist you
May 05, 2013 | Seagull Scientific Systems BarTender...
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
Ihave on bartender barcode printer. it is not printing any thng. ant thing from pc if we are doing Self Test then it is writting 4-5 lines in unknown language and going to stop suddenly. So pls...
Dear Mr.anil279,
Try these things,
1) Re-start Bartender S/w and Printer Main Power and also the system
2) try now if not check, the printer status, you can find this on the taskbar near the system time, check whether the printing is in queue or in cancelled state.
sometimes if any print out get jammed, it will just keep on adding the print jobs to the queue.
if so, delete the jammed job and try again,
3) Mention your printer model no, we shall provide you a video or steps to calibrate your printer.
For further details, you can reach us.
Trridev Labelss Mfg Co total barcode solutions Convertors Of Self Adhesive Labels Re-Sellers Of Barcode Printer And Scanners and Thermal Transfer Ribbons
website - www.trridevlabelss.com email - trridevlabelss@gmail.com
For sales or service enquiries, reach us.
Dec 13, 2010 | Seagull Scientific Systems Office...
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Barcode size
Only if you have acces to the software. Are you using a label design program like Zebra Design or Bartender software?
Aug 27, 2008 | Zebra 140XiIII Plus Thermal Label Printer
Seagull Scientific Systems Seagull-Scientific BarTender Enterprise RFID 7.75 Barcode Label Software - P/N BT-RE30 Enterprise License Logo
73 people viewed this question
Top Seagull Scientific Systems Computers & Internet Experts
David Payne
David Payne
Are you a Seagull Scientific Systems Computer and Internet Expert? Answer questions, earn points and help others
