Question about HP Officejet J4680 InkJet Printer
Need to wake up hp officejet j4680 from sleep mode
I cannot connect this printer to my network. It appears that the printer and the network have two different ip addresses. I saw something flash by on the printer saying it was going into sleep mode. The hp laptop will not recognize the printer drivers. Bottom line printer will fax but will not print.
SOURCE: HP Photosmart 2710 is not recognized over wireless connection
light it on fire
Posted on Dec 08, 2008
Teis
  • 340 Answers
SOURCE: HP officejet 4355 all in one print fax scan copier to connect wit
Hi there, and welcome to FixYa,
You will find your driver at this site: - choose your operating system, download and install, plz let me know the result.
/Teis 6ef1705.png
Posted on Dec 29, 2008
bschilz
  • 2049 Answers
SOURCE: My HP Officejet 6500 wirless
Solution one: Plug the product directly into a wall outlet to make sure the power source functions correctly.
1. Disconnect the power cord from the back of the product.
2. Unplug the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
3. Reconnect the power cord to the back of the product.
4. Try to print again from the computer.
NOTE: If the product prints when plugged directly into a wall outlet, the power strip or surge suppressor might not allow enough voltage to reach the product.
If the issue persists , continue to the next solution.
Solution two: A semi-full reset returns the following settings to the factory defaults:
· User menu settings · Telephony parameter values · Country and language selection · Fax memory · Fax journal information · Speed dial and broadcast lists · Personal header information · Junk file numbers
1. Press the Power button to turn off the product, and then unplug the power cord from the wall outlet.2. Disconnect the power cord from the back of the product, and then wait 20 seconds. 3. Plug the power cord into the wall outlet. 4. Press and hold # and 6 while reconnecting the power cord to the back of the product. Press the Power button to turn on the product, and then follow the instructions that display on the control panel to select the product settings.
Posted on Oct 02, 2009
Mhinhi
  • 10 Answers
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Posted on Mar 01, 2010
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Posted on Jul 26, 2010
Can not find printer on wireless network
I am pretty sure the HP J4680 is wireless only, at least I can't find any Ethernet ports on HP Officejet J4680 that are obvious. So first make sure the blue antennae light is on on the left side of the HP panel. If it is not on press the button that says 802.11g and the blue light will light up indicating that the wireless is now enabled. Check now and see if you can see the printer on the network. Power cycle the printer and router and then see if the printer shows up. If you think it is now connected you can go to step 9) below. if not go to the next step
If the above didn't work try and change the wireless settings from the front panel of the HP Officejet J4680. Press the setup button (the wrench) on the front panel, then scroll till you see Wireless Menu and press OK, then scroll till you see Setup Wizard and press OK. The printer will search for all the wireless routers it can find. It should display your wireless router SSID, this is the name of the router. When it shows you the name of the router press OK and it will display WPA Passphrase or WEP passphrase (depends on the security you have on your wireless router). If you see the SSID of your router this is a good thing, because it indicates that the wireless is working and just needs to be configured. Now type in the passphrase exactly (the same passphrase you use to connect your PC or Mac to the wireless internet) and press OK. It should connect to the wireless router. If this doesn't work, unplug and plug in the wireless router and the printer and try it again. If you think it is now connected to the wireless, then go to step 9) below. If the above doesn't work you can keep trying it but I haven't had much luck with the front panel method.
If the above fails to work, the next method to try is to connect a PC or Mac directly to the HP Officejet using the AD-HOC wireless method. I can't figure out how to get the HP printer into this AD-HOC mode unless I do a wireless reset of the values in the printer. There is prob a way to do this without a reset, but I couldn't get it. I would recommend you read through all the steps below before you do this. It will wipe out what you currently have setup in your printer. But these are the steps I just went through and I got my printer to connect to my MAC and work.
1) You might not have to do this step, but if all else fails reset the HP Officejet J4680 network by pressing the setup button (the wrench) go to Wireless Menu and Press OK then go to Reset Wireless select YES and press OK. If that doesn't work then there is another reset that I found in the setup menu (the wrench) under Tools and then Restore Defaults. I wound up doing both resets on my Officejet J4680
2) Power the HP Officejet off and on for good luck (again optional but might help).
3) Make sure the the wireless on the printer is enabled by pushing the button on the left side front under the 802.11g so that the blue wireless light turns on. (again optional, but make sure the blue antennae light is on)
4) Connect to the HP Officejet J4680 wireless printer directly from the MAC (this is pretty neat stuff) click on the Airport icon at the top bar of your mac screen, if you see the hpsetup listed then click on it, if it is not listed then click on join other network and type in hpsetup and click Join. This will join the mac to the Ad Hoc HPSetup network and you can now setup the printer from the mac!
5) Important: Print a network settings report on the HP Officejet by pressing the setup button again (the wrench) go to Print Report and press OK, go to Network config and press OK. If you try and print this before you connect (step 4) you will not get the info you need in the report, so connect first from Mac to HP then print this report.
6) fire up safari or Firefox or chrome browser on the Mac and type in the URL that is listed on the report you just printed out. It starts with http:// type in the http:// and the 4 numbers all together with no spaces into the address bar in your browser and press return.
7) you are now connected to the HP Officejet J4680 via the web browser interface. Click on Networking, then Advanced, click the infrastructure tab, type in the SSID of the wireless router (i.e. the name of the router you see when you try and wirelessly connect from a computer) and fill in the passphrase info for your router, type it again to confirm, then click apply.
8) The printer will change the connection from the Ad-Hoc network to the SSID of the wireless router. So you have to connect to the wireless printer, to do this on a MAC, you go to the top row of the mac and click the Airport icon, select the wireless router.
9) Now go to the spotlight icon (far right top row on the mac) type Print and then click on Print & FAX, if your printer is not listed, then click the + and add it. You should be able to check the supply levels on the HP, if you see the current time below the supply levels you are successfully connected. On a Windows system, you would go to control panel, then Printers and add your printer if it is not listed.
Also, below is a good video with even more detailed info:
10) Officejet J4680 setup via the mac using this very thorough guide: http://www.youtube.com/watch?v=Rjd1ZqJ89N4
edh 1-13-2011
Jan 07, 2011 | HP J4680 Office Jet All-In-One Printer
HP Officejet J4680 Was connected to home wireless network for 8 months. Now won't connect. Tried everything. Router works perfectly with all computers & internet.
Shut down all computers and another devices connected to network. Shut down Router. Wait 3 minutes. Power on Router. Wait. Power on all devices.
Nov 07, 2010 | HP J4680 Office Jet All-In-One Printer
Have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it
Power Save Mode.Just press the on/off button or wait for the printer to wake up when you start a print job.
Nov 07, 2010 | HP Officejet 6500 Wireless All-in-One...
I have an officejet 6500 wireless printer and the printer goes to sleep and wont wake up without unplugging it.
Nov 01, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you turn off sleep mode on the hp officejet 4500?
This no doubt violated the warantee, but I got tired of turning the printer around and unplugging the power cord etc.
So I got a cord switch I had (Ace hardware 31089, others will not doubt work) and installed it in the power cord per directions.
Now it is easy to reach behind printer and cycle the power with the power cord switch and thus wake up the printer.
May 20, 2010 | HP Officejet 6500 Wireless All-in-One...
Print Cartridge Problem: (Tri-Color) See
Top three solutions to this query at HP support are close to your described problem: (not exact) Try the closest match to your error.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+J4680+All-in-One+Printer&qry=print+cartridge+problem+tri-color&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=3692887&productBigSeriesOid=3645080&spid=3692888&opname=HP+Officejet+J4680+All-in-One+Printer&pname_desc=HP+Officejet+J4680+All-in-One+Print%2FFax%2FScan%2FCopy&ptype=consumer&stype=pn&contextual_lname=&spname=HP+Officejet+J4680+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&product_line_code=DU&search=0
Nov 28, 2009 | HP Officejet J4680 InkJet Printer
Officejet J4680 won't printer after router reset
4) Connect to the HP Officejet J4680 wireless printer directly from the MAC (this is pretty cool stuff) Click on the Airport icon at the top bar of your mac screen, if you see the hpsetup listed then click on it, if it is not listed then click on join other network and type in hpsetup and click Join. This will join the mac to the Ad Hoc HPSetup network and you can now setup the printer from the mac!
7) you are now connected to the HP Officejet J4680 via the web browser interface. Click on Networking, then Advanced, click the infrastructure tab and fill in the passphrase info for your router type it again to confirm, then click apply. It should now connect and print from the router. But below is a good video with even more detailed info:
8) More Officejet J4680 setup via the mac using this very thorough guide: http://www.youtube.com/watch?v=Rjd1ZqJ89N4
Jul 15, 2009 | HP J4680 Office Jet All-In-One Printer
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
Open Questions:
See all HP Officejet J4680 InkJet Printer Questions
HP Officejet J4680 InkJet Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
