Question about Akai MPC-4000 Plus Production Center (w/80 GB Hard Drive&Onboard Sounds)
Pads not responding
My entire first vertical row of pads (pads 1,5,9,and 13) aren't responding. If I press them REALLY hard, they'll respond, for a short period of time. What can I do to fix this?
2 Suggested Answers
SOURCE: Top row of pads don't work, can I fix them? MPC2000xl
go here:
http://www.mpcstuff.com/pad-sensors-with-ribbon-for-mpc.html
there is also an install video.
i have the same exact problem.
best,
m
Posted on Apr 23, 2009
The touch pad on my 990 legacy remote does not work?
The touch pad does not respond
Claudia, dismantle and try to clean or just replace with a good universal remote.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 25, 2016 | Televison & Video
My lenovo keyboard gapslock always on even when you off it and the keys on the same row with z always display something else like when you press z it will display z1 and the touch pad may not respond at...
keys may need cleaning(compressed air)... if you get the same errors each time you can download a free utility for remapping the keys on your keyboard, a google search should help you find it, i forget the name of it. download.com has it i think
Dec 19, 2013 | Computers & Internet
I am using acer aspire series laptop that after an year of use bacame very slow. The entire operating system responds so slowly that often it shows the messege "not responding". My laptop came with pr
I would consider replacing mccafe antivirus because really slows the system down. Go to www.download.com Type: malwarebytes anti-malware and ccleaner, run malwarebytes first and do a full scan, followed by ccleaner, and finally defrag the hard drive. This should help speed up your system.
May 15, 2012 | Acer Computers & Internet
Asus eeepad netbook is frozen. Nothing is responding
Wow, you really need a cd drive to help repair it. Your only option now is hope that the System Recovery will work.
Read your manual as to which key to press to get the Recovery started. You'll lose all your data.
May 04, 2012 | Computers & Internet
Whirlpool washing machine 6alsr7244mw3 always out of balance in spin cycle. Machine balanced/level on concrete floor and doesn't matter what size the load is, in it.
A very common call I get on Whirlpool built direct drive washers, and one of very few problems they have, is that the machine vibrates like it's out of balance when spinning even without any clothes in the basket. Sometimes it'll walk across the floor if this is allowed to worsen.The cause is nearly always support pads. The entire mechanism rests on these three small plastic pads, and when they wear even a little bit, the machine will vibrate like crazy in spin, like its load is badly out of balance. Replacing these pads (part 285744, around 10 for the set will nearly always correct this problem. And they aren't hard to replace if you re just a little handy Here s how Unplug the washer. Remove the 2 Phillips screws that retain the console. On some machines, these are hidden under console end caps that must be pried off. On newer models they re on the back of the console Rotate the console fwd then up and back it will hang back out of the way if the washer s away from the wall far enough.Unplug the white lid switch plug and pry up the 2 large clips that hold the cabinet to the washer back panel.Tilt the entire cabinet forward and it ll unhook from the retainers on the base. Lift the cabinet off and set aside (not as heavy as it sounds With the cabinet off you ll see 3 large horizontal springs, one in each corner of the support 'tripod and one smaller, vertical one in the left-rear that counterbalances the motor's weight. Unhook all 4 of these springs and insert a small piece of 1 by (5 8 or 3 4 thick) board to prop the mechanism up, to access the pads one at a time. Insert the piece of wood between pad locations, on a side of the support triangle a helper's handy here Use a little lighter fluid to clean the mating surface of the support plate that these pads ride against before inserting each new one. Be careful not to scratch the support plate when working under it it needs to be smooth and contaminate-free. Knock the old pads out one at a time, by lightly tapping on their mounting pins from underneath with a hammer. Put each new pad in place in its mounting holes, carefully remove the wooden 'shim then stand up and push down ******* the tub on that corner. You ll hear and feel the pad snap into its mounting holes.Repeat this process for each of the other two pads mounted on the support tripod' (do the rear, 'fun' one last after you have experience replacing the other two and your washer will behave a whole lot better in the spin cycle. And if you have any trouble finding these support pads locally, let me know. I keep lots of them in stock. You can order a set here Oh, and remember to reach around and pat yourself on the back! You just saved yourself at least 100.00
Oct 25, 2011 | Whirlpool Washing Machines
The cursor is frozen and is not responding to the pad.
most likely you have in inadvertently deactivated the touch pad,
do you have an external mouse?
if so does it work
y/n
if yes (you have rebooted your pc at this point, right? if not do so now)
assuming the above look at your row of "F" keys (above the numbers, F1, F2 ect)
there is probably one that has a picture of something like a finger touching a box with a line through it
pick the one that looks the most like this and press it and the key to the left of the space bar that says FN (or some other variation of function on it) at the same time
does this solve the problem
if not try other keys in the F row along with the FN key
if not
repost
Nov 11, 2010 | Acer Aspire One PC Notebook
14 month old LG Microwave. The control panel is
Very common , You need to replace the switch membrain , this is the entire touch pad , they are not to much $ , and you should find it easy online.
Phil
Apr 10, 2009 | LG LMV1630 Convection/Microwave Oven
Mirrors not responding
Sometimes the mirrors outside may have been pushed all the way by hand to one side on a Ford and it's as simple as you lightly pushing it by hand, then move the switch on the inside. A kid or car wash may have pushed it in hard and it's hung.
Jun 17, 2008 | 2000 Ford Taurus
Computers & Internet Logo
32 people viewed this question
Top Akai Computers & Internet Experts
Alun Cox
aravind shet
aravind shet
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
