Question about Plumbing
Need diagram of smh90 onga pump
How to put one back together
SOURCE: a schematic diagram
need a kit to repair framing nailer ns289000
Posted on Nov 17, 2008
  • 188 Answers
SOURCE: pump put together wrong
Here is a link to the owners manual included is a parts list... http://12.153.20.74/manuals/123919-01A.PDF. If you need a part you may want to try www.masterparts.net. They seem to be the only guys who have any.
Hope this help ...
Posted on Mar 05, 2009
VtToolMan
  • 704 Answers
SOURCE: I need to know how to put the pump assembly back
Go to the link provided below and under the heading "Browse Subcomponents" click on the "Pump and Motor Parts" link. I think that shows what you're looking for. Otherwise, check the other diagram links for your model on the same page.
Hope this helps!
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=6651514590&pop=flush
Posted on Jul 28, 2009
franktilt
  • 403 Answers
SOURCE: need a diagram of a 1994 ford ranger water pump?
autozone.com sign up its free then click on repair manuals you will find all of your info there....good luck
Posted on Jun 04, 2010
heatman101
  • 43501 Answers
SOURCE: i need to know how to put bissell proheat 2x back together
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghsgh
Posted on Sep 30, 2010
How do I prime a onga smh90 pump
pour water in the discharge line or remove the plug at the top of the housing and fill it there
Mar 25, 2016 | Plumbing
How much zeoclor in an LS 24 onga
Does not matter on pool size, but on the filter tank size!
Follow Zeo's label instructions, as they may recommend a reduction of their product vs. Sand, say 80% of recommended sand amount. Good luck
Feb 23, 2015 | Pool & Spa
Onga pump does not prime
Theres a pvc Check Valve on the suction side of the pump.This stops water from being able to flow .Depending on age of pool it should be 1.5 to 2 inch fitting.Replaceing this should solve your problem.I there isnt one .Put one in.Around $12 at Home Depot.Link
javascript:openLayer('popup-enlarge-image');
Hope this Helps
Dec 16, 2012 | Plumbing
Onga sand filter pumps sand in to pool ,just got re connected to new above ground pool
The lateral(s) are damaged and allowing sand thru and back to the pool. I have never dealt with that specific brand to know if the laterals come as one assembly or individual pieces. You'll need to contact the dealer you got the unit from or check online at http://www.onga.com.au/dealerlocator for someone in your area.
Dec 05, 2009 | Pool & Spa
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Sep 07, 2009 | Plumbing
Hope this helps!
Jul 28, 2009 | Kenmore Dishwashers
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Plumbing Logo
29 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
