Question about Atlas Copco 15hp Rotary Screw Air Compressor W/ Dryer - 80 Gallon Tank
Temperature indicator P.N. 64818-012-1 - Atlas Copco 15hp Rotary Screw Air Compressor W/ Dryer - 80 Gallon Tank
Temp guage not working 1999 alero
One advantage us dealer tech's have over a week end warrior is that we have factory service repair information and have factory scan tool ,Tech 2 , to check data coming into the instrument cluster . Most of you probably don't even think about how that coolant temp infor shows up on the gauge , except by a coolant sensor !
High Temperature Indicator
The high temperature Indicator function handles the control of the Engine Temperature Gauge Display and the red High Temperature indicator. The Powertrain Control Module (PCM) reads the Coolant Temperature Sensor, filters the messages, and sends the coolant temperature to the instrument cluster via a Class 2 serial data message. The PCM monitors the coolant sensor in order to determine a fault. The PCM transmits the Class 2 serial data coolant temperature report messages to the instrument cluster for the temperature gauge display and for the high temperature indicator control.
The instrument cluster receives the engine temperature data in the Class 2 serial data message from the PCM. The instrument cluster converts this data into a temperature gauge pointer position which drives the gauge pointer. The instrument cluster also uses this data in order to determine the high temperature indicator control.
The Body Control Module (BCM) looks for the high temperature indicator Class 2 serial data report from the instrument cluster and triggers a chime when the indicator is ON.
Your best bet , take it to a qualified repair shop , rather then just replacing parts .
Feb 10, 2017 | 1999 Oldsmobile Alero
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Saber que es codigo 15 codigo 20 y codigo 25 isuzu trooper mod 1988 gasolina 2.600 cc. inyectado
Revise estos codigos correspondientes al sistema OBD I...
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 EGR system fault
33 MAP sensor circuit (signal voltage high, low vacuum)
34 MAP sensor circuit (signal voltage low, high vacuum)
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM error (faulty or incorrect MEM-CAL).
Suerte.
Apr 18, 2011 | 1987 Isuzu Trooper
Onece the range selector is turned on the light comes on but soon goes out, if you move the selector a little the light comes back on, this stove was made around 1952. Thank You, Dave
Are you talking about the oven temperature control? When turned on to the selected temperature the oven indicator will light and the element will work. When the oven reaches the desired temperature the power will shut off to the element and the indicator light will go out. When the oven cools slightly the indicator light and the element will again turn on. When it does turn off and you turn the knob slightly to increase the temperature the indicator light and element will come on again as you are asking it to heat to a higher temperature. This is normal oven operation.
Mar 10, 2011 | Kitchen Ranges
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
Which side ofintake manifold does temperature gauge sending unit go on
Water Temperature Indicator Sender Unit
The water temperature indicator sender unit is installed on the engine into an engine coolant passage. The water temperature indicator sender unit reacts to the engine coolant temperature. Its resistance decreases as the engine coolant temperature increases.
Water Temperature Indicator Sender Unit Removal
swb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not mix Standard (green) Coolant with Extended Life Coolant (orange). If mixing occurs, drain engine cooling system and refill with originally equipped coolant type. If this contamination occurs the service change interval on Extended Life Coolant will be reduced from 6 years/150,000 miles to 3 years/30,000 miles.
  1. Partially drain engine cooling system as described.
  1. Disconnect engine control sensor wiring (12A581) from water temperature indicator sender unit (10884) .
  1. Remove water temperature indicator sender unit.
Jul 30, 2010 | 1998 Ford Mustang
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
How many indicator lights are there and where are they for 2009 f150 supercrew
Item Part Number Description 1 — Tachometer 2 — LH turn indicator 3 — Oil pressure gauge 4 — Overdrive (O/D) off/tow haul indicator 5 — Engine temperature gauge 6 — Air bag warning indicator 7 — Safety belt warning indicator 8 — Fuel gauge 9 — Tire Pressure Monitoring System (TPMS) warning indicator 10 — Speed control indicator 11 — Transmission temperature gauge 12 — RH turn indicator 13 — Speedometer 14 — Malfunction Indicator Lamp (MIL) 15 — Message center indicator display area 16 — High beam indicator 17 — ABS warning indicator 18 — Brake warning indicator 19 — Message center display area 20 — Anti-theft indicator
Feb 27, 2010 | 2009 Ford F-150
Cooling fan operation
sounds to me like the thermostat is sticking and allowing the car to overheat. with the a/c on the fan comes on and runs constantly to keep the engine cool
Oct 22, 2009 | 2000 Ford Focus
Atlas Copco 15hp Rotary Screw Air Compressor W/ Dryer - 80 Gallon Tank Logo
Top Atlas Copco Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Atlas Copco Air Tool and Compressor Expert? Answer questions, earn points and help others
