Question about Watches
Longines automatic admiral 10k gold filled remove bezel to use 1260 wrench
Longines automatic admiral 10k gold remove bezel to use 1260 wrench
3 Suggested Answers
  • 299 Answers
SOURCE: If I buy a Longines 10K gold filled watch, what is
Gold filled is simply a very thin layer applied to the base metal case and will wear off over time. Solid 10K gold is an alloy that is mixed with gold throughout and will always retain it's color and never wear off. The solid 10K gold case contains a lot more gold than then the gold filled version and will cost more up front. However, the gold filled case will look awful in a year or two while the solid 10K case will last as long as you keep the watch and beyond.
Posted on Apr 22, 2010
Testimonial: "Thanks for your advice, I'll bear it in mind."
ginko
  • 19396 Answers
SOURCE: i have a longines five
Hi.
A 1100 wrench is a professional tool that shrinks the crystal applying balanced pressure to removed it without damaging it. Technically the part is a precision crystal compressor tool consisting in a metal wrench and adaptable rings. Here how it looks like (the one below is a 1200 - only the diameter is different - shape is the same) :
Once crystal is out the movement comes out through the front of the case, the back does not open and it is all in one piece
Don't try to open the watch by yourself. you will damage the case. The watch is still worth over $500. If you are located in USA I suggest contacting the professional repair below. If you are located elsewhere find a local Longines repairer or a vintage watch repairer.
Check Repair Service here
Regards.
Ginko.
Posted on May 30, 2011
Purchased a new 18k gold bezel to replace the bezel that has the gold worn off.
whats the problem are you trying to fit the new bezel? you will also need to ensure the bezel retention spring is with the bezil
Apr 10, 2014 | Tag Heuer WAF2110.BA0806 Aquaracer...
I'm looking for the worth of a ladies Bulova watch with 10K Rolled Gold Plate L3 1131948 on the back.
i have a bulova same no. speidel pat. but the serial no. u lookin is different this one is 10kt rolled gold plate back.
Oct 20, 2011 | Watches
I have an old (1991) Corum Admiral's Cup watch and need to remove some links. How do I do that? Thank you for your time.
mcdevito75 Here, You"ll need a special toll called a link remover tool, available on ebay, however if you"ve never done work or this particular work on watches, your best bet is too find a small watch repair shop in your area for the link/s removal.
Sep 01, 2010 | Corum Admiral Cup 18K Yellow Gold Blue...
I WOULD LIKE TO ITS TRUE VALUE
mcdevito75 here, Many factors figure in the value of a watch, Of course you have a NAME watch Longines which helps a great deal, First, if the hands are thick, the watch is before 1969, if they are thin, anywhere after 1969, Original strap or band conts, a good, good replacement band is ok. the appearance of the watch, no scratches opr buffing, scrapping on the caseing, no scratches or cracks in the crystal (glass) of course being vintage there will be some evidence of age, and lastly time keeping, if your Longines works well keeps time all day, I estmate it"s value, anywhere from $125.00--------- $200.00. You can also check a small watch repair shop in your area or jewelery shop, they will usually give a rough estmate of value for free.
Jul 17, 2010 | Longines 10K Gold Filled, Manual Wind...
If I buy a Longines 10K gold filled watch, what is the difference between that and solid 10K gold? and is there a big difference in the price of 10K gold filled per gramme and solid
Apr 22, 2010 | Longines 10K Gold Filled, Manual Wind...
How do i set an older longines automatic admiral watch to the correct date and day
You can get instructions from their web site but if your watch is really old, then it seems unlikely that any of the instructions there are for your watch.
However, since watches tend to have similar features (although not the modern electronic types), a basic modern watch probably operate in the same manner.
Go to "www.longines.com/watches/instructions" and have a look at the range of instructions there to see if they are any help.
If nothing useful is found look at the "official retailers" to see if there is a local shop that can help you.
Mar 08, 2010 | Watches
Hello, my longines 14k 17J, case number 975099 Can you help me find the information about this watch?
Contact Longines yourself by following this link: http://www.longines.com/contact/faq/products Find the best suitable way for you to get in touch and ask for the information you are after. Rate me, plz.
Jan 28, 2010 | Longines "Fancy Case" 14K Gold, Manual...
How do i change the date on a 1960's longines Admiral?
If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
Jan 14, 2010 | Longines Watches
Appraise Bulova N2 10K R.G.P. Bezel Stainless steel back
I have seen this watch sale in mint condition for as much as $40 but this is an inexpensive piece.
Sep 14, 2009 | Watches
Face almost unreadable;can only adjust winding back;stops intermittently.
Hi Murbilpov,
thank you for using fixya, you have a very fine piece of jewelry. it appears that your watch needs cleaning right on the knob and adjust mechanism. as per a service document from longines, a possible build-up or a broken first gear may cause this issue.
you may refer to their official statement when it comes to cleaning and having the watch repaired.
1) Where should I send a Longines watch that needs to be repaired, adjusted or serviced?If your Longines watch needs to be repaired, adjusted or serviced, werecommend that you bring or send it (well padded and by registereddelivery in the latter case) to your nearest Longines authorizedservice centre. You will find its address in your guarantee booklet oron our website in the Customer Service section.
2) Is the repair of a Longines watch that is more than 20 years old still possible?Yes, we still repair vintage watches at our head workshop in St-Imier.
However, without having the watch to hand, it is impossible for us tojudge its state and to know if all the necessary spare parts for therepair are still available.
Therefore, we kindly suggest that you send your watch via the nearest Longines authorized servicecentre to the Longines head office in Switzerland. Upon receipt andafter analysis of your watch, we will send you our comments and a priceestimate for the repair of your watch.
3) How often do you recommend having a maintenance service carried out on a Longines watch?We would like to draw your attention to the fact that a watch used daily is running 24 hours a day, 7 days a week non-stop.
The frequency of the maintenance service depends on the type of watch, the climate and the care taken by the watch wearer.
In general, it is necessary to have your watch controlled andserviced at least once every 4 - 5 years, just like any other precisemechanical device. This guarantees the reliability and rate precisionof your watch.
4) Which operations are included in a complete maintenance service?The following operations should be included in the price of a complete maintenance service:
– complete dismantling of the movement, cleaning, oiling, reassembling, regulating and the checking of functions;
– repair or replacement of movement components that are either worn or faulty;
–replacement of the following parts: glass, crown, push-pieces, sealsand battery if a quartz calibre (parts included in the price of theservice, with the exception of shaped mineral glasses and sapphirecrystals);
– restoration of the water-resistance (if a water-resistant model);
– refurbishing of the case or bracelet (two-tone, gold-plated and PVD-coated cases and bracelets, cleaning only);
The above service standards are only valid for the Longines head office in Switzerland.
5) Which operations are included in a partial maintenance service?The following operations should be included in the price of a partial maintenance service:
– during each partial basic repair, Longines undertakes to check theregulation of the movement and replace the glass (if necessary), thepipe, the crown, the push-pieces, the seals and the battery in the caseof a quartz movement (these parts are included in the price, with theexception of shaped mineral glasses, sapphire crystals, and restorationservices carried out on the dial, case and bracelet. Parts made out ofnoble metals will be invoiced separately);
– restoration of the water-resistance (if a water-resistant model) and cleaning of the case and bracelet;
Any repair that necessitates the replacement of a part, or any servicementioned in point 7 automatically involves a partial basic service.
Hope this helps, should you have other questions, please do not hesitate to let me know.
regards,
voodoo
Apr 22, 2009 | Longines Watches
Watches Logo
367 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
