Question about Air Ride Management 2004-2008 Opel Astra G, Astra B, Caravan, Zafira, Vauxhall, Holden, Plug and Play Air Suspension Kit
Fan won't turn off after taking out ignition switch
When I turn car off it appears the car sounds like its still running but I think its the thermostat of the fan
  • Lee Berggren-Levitt
    Lee Berggren-Levitt Feb 13, 2014
    Its a Holden Zafira and I meant to say sounds like its still running after keys taken out of ignition. One person said they think is the thermostat fan switch relay stuck
    Lee Berggren-Levitt Feb 15, 2014
    So what it appears is the fan is still running after I pull the keys out of the ignition. Just now driving home temperature over 100 and when we drop open the bonnet and I can see coolant disappearing before my eyes. Doesn't drain out on the ground but there is a slight popping and squeaking sound as its emptying. I've refilled it up after it cooled down and appears to be fine but have no idea what's going on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 127 Answers
Have a look to see if the fan is working and if it will not stop get an Auto Elect to fox the current leakage
Posted on Jul 28, 2015
Free mechanical advice online
I think you already know the answer, based on what you described. Your ignition switch appears to be worn beyond usability. It is also unsafe, as it could just as easily cause the car to stop while running (similar to the mess GM is in today). I recommend replacing the ignition switch as soon as you can.
Mar 24, 2014 | 1995 Ford Mustang
I have a 2002 Ton and country minivan. The blower fan is running at the same speed while the ignition is on. The blower fan cannot be turned off or the speed adjusted by the switch. Is this a switch...
it sounds like the blower motor resistor is bad . it is located behind the glove box and is very easy to replace. i think it was about 40 bucks. i hope this helps .
Apr 20, 2013 | Chrysler Town and Country Cars & Trucks
Radiator fan running when the cockpit heater is ON
If you you are running it in Defrost the A/C will turn on to dry the air thus turning on the Rad fan also check to see if your A/C switch is turned on.
Feb 15, 2013 | 2004 Volkswagen Passat
Sounds like the starter is continuiously running. whats the problem?
I believe this car has an electric cooling fan, It is normal for it to run after the car is turned off until it cools down, If it is the starter turning the ignition switch is worn out and sticking , This switch should be located at the lower end of the steering column. I hope this helps.
Feb 14, 2013 | 1996 Chrysler Cirrus
91 honda accord fan stars when you shut off engine
There are two fan switches on that car;
The main one turns the fan on and off when the ignition is on and the car is running.
The second switch powers the fan if the ignition is off and the engine temperature is too high, to cool the engine off if it was just shut down.
It sounds like your main fan switch has gone bad and needs to be replaced since it's not sending any signal to the fan, while the engine is running.
Oct 22, 2012 | 1991 Honda Accord
2001 jaguar s-type won't crank battery new and charged. Turn the ignition car won't make a sound
many things will cause no start problems could have faulty ignition switch.use test light see if power going to starter if not check ignition fuse to starter.if power going to starter, more likely starter solenoid or starter faulty.if ignition fuse okay and starter and solenoid okay still no start problem could be in the ignition switch or inhibitor switch faulty.code scan for faulty theft security system which will also cause no start conditions.
Oct 22, 2012 | 2001 Jaguar S-Type
Grand Am 2003 won't start
Sounds like your key is no longer actuating the starter/not matched to the vehicle key code, if you can turn it on but no cranking action is done when trying to start.
Sep 03, 2017 | 2003 Pontiac Grand Am
Crankup and drive get some place and shut it off them sometimes wont restart till it cools. checked relays battery alternater all is good what is wrong ?
If your starter won't turn over after driving and shutting the car off, sometimes, it sounds like your starter is getting stuck/overheating. Replace your starter and this problem should go away.
Oct 08, 2011 | 2003 Saturn ION
Mu 1991ford tempo fan wont turn off when i turn
does anything else stay on it sounds like you have a bad ignition switch
Dec 14, 2009 | 1991 Ford Tempo 4 Door
Riello 40 F5 oil burner, on boiler, intermittently running
with a forced draught burner the fan motor would be checked via a pressure switch. if the pressure switch is not set correctly or the fan is too weak the contacts will not be made in the switch and the burner will lockout. if the damper is not open enough when the fan runs then the air supply will be too small for the switch to make. check to see if you have a capacitor on the fan windings if this is faulty then the fan will fail intermittently.
Jan 19, 2009 | Heating & Cooling
Air Ride Management 2004-2008 Opel Astra G, Astra B, Caravan, Zafira, Vauxhall, Holden, Plug and Play Air Suspension Kit Logo
198 people viewed this question
Top Air Ride Management Air Tools & Compressors Experts
Andrew Taylor
Andrew Taylor
Timllfixit
Are you an Air Ride Management Air Tool and Compressor Expert? Answer questions, earn points and help others
