Question about Lamplight Farms Montana Ind Oil Lamp 50840
Does this product come with a wall mounting bracket
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
Want to mount tv lg 42lg50 42 in. on wall...which screws you use for drywall
You don't use screws for drywall to hang a TV, EVER.  That's a 50 pound TV.  You should only use the heavy stud bolts that came with mounting bracket and bolt them directly into the studs.  If by some chance the mounting didn't come with them, go to Home Depot or Lowes with the mounting tell them what you're doing and they'll get you what you need.  You are using a mounting bracket, aren't you? If by some chance you're trying to do this without a mounting bracket, STOP what you're doing and get a mounting bracket appropriate for your size television.  Go to Monoprice, they're the cheapest and their quality is excellent.  Meritline is good as well, they just take a little longer to get.  See the video below.
utube.png You-Tube video "lCNyc-KgCDY" placeholder [unremark-end]-->(do not delete) utube.png
http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10828
http://www.meritline.com/tv-wall-mount---c-13552.aspx
Apr 22, 2011 | LG 42LG50 42 in. LCD HDTV
Can I wall mount my proview tv? do I need to buy a particular mounting bracket?
You can wall mount your Proview TV with any standard VESA mounting system that is certified for up to the size of you tv.
Feb 03, 2011 | Sony SUWL500 Wall Mounting Bracket
Is there a wall mount bracket for this or any of your products?
Most all sets today can have a wall mount bracket available. I would go to Best Buy.
Dec 10, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
Trouble mounting cantilever wall mount bracket to Sony TV
Finally figured out the correct arrangement or configuration through trial and error (and my wife's puzzle solving ability). It sure wasn't clear in the instructions, and I could not get the needed information from the website of either the manufacturer of wall mount system or TV...a little frustrating, but perseverance paid off. Given the price of the wall mount, I would think they could do a better job.
Oct 24, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Can the 19av500u be mounted on the wall
yes to find proper mount google 19av500u wall mount PLEASE make sure it is screwed into a 2-by-4 in wall
Sep 02, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Lamplight Farms Montana Ind Oil Lamp 50840 Logo
443 people viewed this question
Top Lamplight Farms Home Experts
Donni Steen
Tom Chichester
Are you a Lamplight Farms Home Expert? Answer questions, earn points and help others
