Question about Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series
Does this have a programmable timer (not sleep timer)?
SRP5107/27 remote control ..where is the 'sleep timer'
No, it doesn't. Then again very few universal programmable remotes do. It's a feature very seldom used by the general public.
Did you not check before you bought it?
Can you access the TV's Sleep settings via the TV's onscreen menu instead?
Sep 08, 2014 | Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Since changing to freeview in april i no longer need the use of the original tv remote as the new remote is being used. my problem now is i cant find how to set the tv to sleep mode shud i fall asleep...
Your new FreeView remote will only support the essential functions of your tv. In some cases that's limited to volume up and down, sound mute and on/off only, but often they can do more. Sleep timers are rarely supported.
Your fix is to either set the sleep timer on the old remote, or to buy another fully programmable learning remote control, where you can customise almost every button and use your old remote to teach the learning version its tricks.
Jul 22, 2011 | Televison & Video
How can i programme the tv to switch off the same time every night
go to menu then sleep timer. that should do it let me know
Mar 17, 2011 | LG Televison & Video
I do not know how to set the sleep timer without having to go through too many steps. Do not want it repeated every night
Hi there
Do you have the model number of your LG TV? Sometimes they have programing functions in the timer menu. There you can programme it to do exactly as you want.
Hope this helps
TV_Doctor
Jan 03, 2011 | LG Televison & Video
Can't set the sleep timer
I have the same problem. Does anyone have a fix?
Dec 23, 2008 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Sleep timer has been activated and i cant turn it off
Your T.V.s Sleep Timer feature is a programmable automatic timer that will turn your TV off after a certain amount of time. Just reprogam it to the amount of time you want. You probably find that in the menu of your T.V.
Thanks!
Jun 20, 2008 | JVC AV-27D502 27" TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series Logo
20 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
