Question about Casio Office Equipment & Supplies
Syntax error every time i enter 11,784 times 5,201 and press equal syntax error pops up, why does this happen?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Don't enter the commas. Just press 1 1 7 8 3 * 5 2 0 1 =
The calculator interprets a comma as separating two items, not as part of a single number.
Posted on Feb 13, 2014
Testimonial: "ok, thank you"
4 Suggested Answers
SOURCE: syntax error on TI-30XIIS calculator when i press
I had the same problem and finally figured out how to fix it. You need to clear the memory. To do so, first press and release the 2nd button at the top left of the calculator. You will see "2nd" appear on the screen at the lower left. next press the 0 button (which 2nd function is "Reset"). The key to making this work is: do not hold the 2nd button while pressing the 0 button. You have to press it, release it, and then press the 0 button.
Posted on Nov 08, 2010
  • 7993 Answers
SOURCE: 5/4x-18=-3 Ti 84 plus
If you wan to solve an equation using the SOLVE feature you enter it as follows (your example)
You should rewrite it as 5/4*X-18+3 (= 0). Implicitly, the calculator assumes that the right side is ZERO and you do not enter any right side nor an equal sign.
Type in
5/4 [*] [X,T,theta, n] -18 +3 [ALPHA] [ENTER] (SOLVE)
You should get an answer -780/47 or the decimal equivalent (depending on display mode.)
Posted on Feb 12, 2011
Testimonial: "thank you for your help :)"
  • 7993 Answers
SOURCE: restrict domain, every time i
Here is how you restrict a domain.
Posted on Feb 25, 2011
991ES-Plus X-hat syntax error
you can not get directly x^ or y^ directly ,,,,, just enter a number before x^,,,, just like 1x^
May 10, 2014 | Casio Office Equipment & Supplies
Press numbers display syntax error how solve a problem?
The order in which you are entering numbers and operations is not correct. For example, if you enter 5++2 most calculators will flag this as a syntax error.
On some calculators you calculate square roots as follows: 25 [SQRT]= gives 5. That is the correct syntax for this type of calculators.
For the newer ones you press the SQRT key and see displayed the square root symbol followed by a left parenthesis. You enter the number, close the right parenthesis, then =. If you do not respect the order you get a syntax error.
I cannot say more because I have no idea what you were trying to do, and more importantly, I do not know the make and model of the calculator.
Oct 28, 2013 | Office Equipment & Supplies
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Dec 06, 2012 | Mozilla Firefox
I GET ON FACEBOOK THEN I GO TO WSOP SITE CLICK TO PLAY AND NOTHING HAPPENS OR I GET A MESSAGE TELLING ME THERE IS A SYNTAX ERROR (12) . I DON'T HAVE A CLUE WHAT THAT MEANS. ANY HELP WOULD BE APPRECIATED
syntax error - an error of language resulting from code that does not conform to the syntax of the programming language; "syntax errors can be recognized at compilation time"; "a common syntax error is to omit a parenthesis"...
("syntax error" is a kind of...):
programming errorsoftware error (error resulting from bad code in some program involved in producing the erroneous result)
Apr 25, 2011 | Playdom WSOP Poker
Looking for a syntax
I am not sure what you are asking for?
Repeated multiplication (with same factor) is called raising a number (base) to a power. The exponent of the power is equal to the number of times the factor is repeated.
The calculator has several buttons to calculate powers.
For the square X*X you have a key [X^2].
For the cube X*X*X you MIGHT have a dedicated key [X^3].
However all calculators (scientific) have a universal power key marked [^] or [X^y] or [Y^x]
Example : In 5x5x5x5x5x5x5 you have a repeated multiplication, so the base is the factor (5) and the exponent is equal to 5. It is equal to the number of times the factor is repeated.
So 5x5x5x5x5x5x5 can be written much more efficiently as 5^7
Entering 5 then pressing the [^] key, followed by the exponent 7 gives the result 78125.
Jun 23, 2010 | Texas Instruments TI-30X-IISTK Scientific...
I get syntax error on every function - no matter what i do...any ideas? is the calculator just broken?
If it can complain about your syntax, then it is still working properly.
For certain functions you enter the number, press the function key and you get the answer.
For other functions, you press the function key, then the number, and after that the equal sign to get the result.
Which functions work one way and which the other way? You will find the answer in the manual that shipped with the calculator. If you no longer have it, post a comment to this thread and I will give you the link. Or you can go to education.ti.com >Downloads>Guides>Scientific calculators and find the one for your calculator. Download it and read the examples.
Apr 08, 2010 | Texas Instruments TI-30X-IISTK Scientific...
-2[3x-5 (2x-3)]=3x-8 how do I do the brackets and the equal sign in this equation? When I try to use the regular = sign in the bottom right I get a syntax error?
Use the other = sign obtained by pressing [ALPHA][CALC]. You also use the[ALPHA] key before entering X,Y,A,B,C.D variables.
The = sign at the bottom that gave you syntax errors is in fact an EXECUTE command. It used to be marked [EXE] on Casio calculators
Mar 04, 2010 | Casio FX-115ES Scientific Calculator
Can you correct my error message? command line option SYNTAX ERROR I get this message when I try to open a pps file. I have Microsoft Power Point installed on the computer. Thea.
In computer science a syntax error ( IPA: /ˈsɪntæks ɛrə(ɹ)/ ) refers to an error in the syntax of a sequence of characters or tokens that is intended to be written in a particular programming language.
For compiled languages syntax errors occur strictly at compile-time. A program will not compile until all syntax errors are corrected. For interpreted languages however syntax errors cannot be detected until runtime and it is not necessarily simple to differentiate a syntax error from a semantic error.
A syntax error may also occur when an invalid equation is entered into a calculator. This can be caused, for instance, by opening brackets without closing them, or less commonly, entering several decimal points in one number.
copy and paste this link in your internet address bar for more information:
http://www.google.com/search?q=SYNTAX+ERROR&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
feel free to ask any other questions
Oct 13, 2009 | Microsoft Windows Vista Home Premium with...
130 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
