Syntax errorevery time i enter a comma in 11,783 times 5,201and then press equals syntax error pops up. Why??
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Don't enter the commas. Just press 1 1 7 8 3 * 5 2 0 1 =
Posted on Feb 13, 2014
4 Suggested Answers
SOURCE: syntax error on TI-30XIIS calculator when i press
I had the same problem and finally figured out how to fix it. You need to clear the memory. To do so, first press and release the 2nd button at the top left of the calculator. You will see "2nd" appear on the screen at the lower left. next press the 0 button (which 2nd function is "Reset"). The key to making this work is: do not hold the 2nd button while pressing the 0 button. You have to press it, release it, and then press the 0 button.
Posted on Nov 08, 2010
  • 8073 Answers
SOURCE: 5/4x-18=-3 Ti 84 plus
If you wan to solve an equation using the SOLVE feature you enter it as follows (your example)
You should rewrite it as 5/4*X-18+3 (= 0). Implicitly, the calculator assumes that the right side is ZERO and you do not enter any right side nor an equal sign.
Type in
5/4 [*] [X,T,theta, n] -18 +3 [ALPHA] [ENTER] (SOLVE)
You should get an answer -780/47 or the decimal equivalent (depending on display mode.)
Posted on Feb 12, 2011
Testimonial: "thank you for your help :)"
  • 8073 Answers
SOURCE: restrict domain, every time i
Here is how you restrict a domain.
Posted on Feb 25, 2011
Syntax error
The calculator interprets a comma as separating two items, not as part of a single number.
Feb 13, 2014 | Casio Office Equipment & Supplies
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Dec 06, 2012 | Mozilla Firefox
How to calculate integration in fx-991ms
Syntax is $( function,lower bound,upper bound) =
Press the Integral key. $(
Type in the function eg. sin
Type the variable: SHIFT ) to enter X
Type in a comma separator ,
Type in the lower bound of the integral
Type in the upper bound
Close the right parenthesis )
Press = to get the result.
Note: You have to wait for the calculator to return with the answer. Some calculations may require time to perfor.
Jan 11, 2012 | Casio Office Equipment & Supplies
I want to know how to calculate derivative of functions like sinx, logcosx, e^X etc on my calculator
Here it is
The syntax of the command is
where function is the expression you are differentiating
x is the value of variable x at which you are evaluating the derivative, and tol is the tolerance (the error) you are willing to tolerate in the result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral]
To enter the symbol x in the expression you press [ALPHA][ ) ]
To enter a comma you use [SHIFT] [ ) ]
To enter a power of 10 in the tolerance use [x10^X] key
Example : Calculate
The key sequence is as follows
[SHIFT] [Integral] 3 [ALPHA] [ ) ] [X^2] [-] 5 [ALPHA] [ ) ] +2 [SHIFT] [ ) ] 2 [SHIFT] [ ) ] 1 [x10^X] [(-)] 12 ) [=]
DO NOT confuse [SHIFT] [ ) ] which enters the comma and [ALPHA] [ ) ] which enters the variable X.
Jun 29, 2011 | Casio FX-115ES Scientific Calculator
Error 07
Error 07 is Syntax Error. From the manual: "You entered a value; look for misplaced functions, arguments, parentheses, or commas; check the syntax description in the A to Z reference."
If you can't find and fix the error, could you post the expression producing the error?
Feb 16, 2011 | Texas Instruments TI-86 Calculator
How to find derivatives using fx115-es
Example : Calculate
Oct 29, 2010 | Casio FX-115ES Scientific Calculator
Im not sure on how to caculate derivatives on the calculator, help would be appreciated
If you do not want to specify a tolerance just the last comma and tol.
Example : Calculate
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
-2[3x-5 (2x-3)]=3x-8 how do I do the brackets and the equal sign in this equation? When I try to use the regular = sign in the bottom right I get a syntax error?
Use the other = sign obtained by pressing [ALPHA][CALC]. You also use the[ALPHA] key before entering X,Y,A,B,C.D variables.
The = sign at the bottom that gave you syntax errors is in fact an EXECUTE command. It used to be marked [EXE] on Casio calculators
Mar 04, 2010 | Casio FX-115ES Scientific Calculator
20 people viewed this question
k24674
jasbo
jasbo
