Batteries ran out message
Olivetti RT5400 shown "batteries ran out message" what is the fix?
Wont start
Try using another battery or assisted battery connected from another vechile as batteries just die. If the battery is malfunctioning then the error messages are shown.
Jul 25, 2012 | Chrysler 300C Cars & Trucks
My calculator has fresh batteries and will not turn on, it has normally worked before and now it just randomly stopped working.
Did you change the AAA batteries and the internal back up battery? It may sound unnecessary, but sometimes these devices are a little picky. I would also check that the contrast and brightness setting is appropriate. I fixed my dad's just by hitting second and up on the arrow to make the font show up again.
If neither of those work, try these:
(These will reset the calculator and erase the memory)
Remove one of the AAA batteries, hold down on the DEL key while reinserting the AAA battery. The handheld might display "Waiting...Please install calculator software now". If you get this message, the information in the "Correcting the Error Waiting" section shown below will help you correct the problem. Before trying that procedure, reinstall one of the AAA batteries again. This time do not hold down the DEL key.
Remove one of the AAA batteries, press and hold the [on] key for 10 seconds, release, replace the battery, then turn the unit on. Adjust the contrast.
Remove the AAA batteries for three hours. After the three hour period, reinsert the batteries and turn the handheld on. Adjust the contrast if necessary.
Jun 22, 2011 | Texas Instruments TI-83 Plus Calculator
When I try to take a photo the message "battery empty" shows. The batterys are new
Check if the battery are inserted as shown on battery cap.if yes check if the batteries are the ones for the camera.I mean you might have AAA batteries instead of AA type batteries and that's why you receive the message
Mar 31, 2011 | Olympus SP-570UZ Digital Camera
My camera shows a "lens error" message
Hello and welcome
The most common cause for a Lens error:
Misaligned Lens rings
Sand and grid wedged in between the lens and the barrel.
Dropping the camera
Ran down battery
The following solutions are there by which you may Fix the lens error
  • Firstly you can try removing the batteries and replacing it with a new set of fully charge ones
  • If the batteries ran down while you were taking photos with the lens extended, you might also get this error. Remove the the memory card and replace the batteries with a fresh recharged set. Try to power on the unit with the fresh set of batteries while the memory card is removed
  • Connect your camera to your computer using your USB DATA cable which came with the camera. Once the camera gets power in this mode, the screen should stay off, hence, supplying the lens with more power to push or pull out/in
  • Place the camera on a sturdy table with the lens pointing to the ceiling. With a fresh set of batteries installed(Do this without a memory card) hold down the shutter button while you power on the unit
  • Now, you can either use a compressed air canister to blow around the lens area. This will result in the sand or dust particles to be blown out of the area between the lens and the barrel. Or, you can use a vacuum and and carefully place the nozzle around the lens to out the particles
For more solution by which Lens error can Recover Here you Go. It will help you out more briefly
I hope this solution will helpful for u Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 02, 2011 | Nikon Coolpix S4000 Digital Camera
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
Lens error
May 31, 2010 | Nikon Coolpix S210 Digital Camera
Error message on Olympus
Hello evrybody,
I had the same problem but i fix it.
This is the solution :
1- When the "ERR" message is shown, press Disp/Menu Buton for Two seconds and at the same time "Stop" Buton.
2- The "FOR" Message is shown
3- wait for some minutes
That's all
PS : All the recrded messages will be deleted
Mar 01, 2008 | Olympus VN-2100PC Digital Voice Recorder
Olympus VN-2100PC Error Message 'chk' and then 'Err'
Hello evrybody,
That's all
Sep 21, 2007 | Olympus VN-2100PC Digital Voice Recorder
32 people viewed this question
jasbo
jasbo
