Question about Whirlpool GD2SHGX Refrigerator
MOTOR WILL NOT DISPENCE ICE FOR MODEL # KSRS25FTBL00
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: i have whirlppol refregrator model ed2kvexvq01,
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 08, 2011
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Whirlpool 6th sense not making ice or dispenceing water
What is the model number of your unit?
Nov 03, 2012 | Refrigerators
Ice Dispencer is not releasing ice (cubed or crushed)
I would remove the ice bucket in the freezer and make sure that nothing has gotten between the motor and the auger that pushes the ice forward.
Jul 09, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Nov 17, 2008 | Refrigerators
Problem with ice maker
Christy
Depends on the model. BI models or co29 the setting is warmer to make more ice.co2075 you have 2 tstats. So the icemaker control is seperate.What model do you have
Aug 11, 2008 | U-Line Refrigerator Ice Maker
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Mar 02, 2007 | GE GSH25JFR Side by Side Refrigerator
Whirlpool GD2SHGX Refrigerator Logo
14 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
