Question about Dell OptiPlex 330 Desktop Desktop Computer
Loud fan the fan is making clicking noise
Why is it making a loud clicking noise?
If it makes a loud clicking noise on startup or shutdown, it could be caused by a weakness in the springs that hold the compressor in place in the hermetically sealed shell.
If it is a constant noise while compressor is running it could be a slightly bent fan blade hitting its surroundings. Check the condenser and evaporator fans.
Aug 31, 2015 | Refrigerators
Xb31 projector makes loud click noise
Could be anything, you will have to dismantle it and remove the bit of broken plastic/clip/screw ???
Dec 11, 2013 | Computers & Internet
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
Ps3 loud fan noise
Don't do anything your fan is just fine it's just running faster to keep it cool when you hear a clicking sound at high speed then you should be worried about it cause your fan is failing and should be replaced
May 31, 2010 | Sony Playstation 3 (PS3) Console
Our toshiba 42" DLP makes an incredibly loud fan noise sometimes. Sounds like it will blow up. Can this be fixed without costing a fortune or do we just need a new set
Hello.
I can Honestly say this is little information. and i will try to you to a web site that i think it will help you and probably you can fix it by your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1254&p=4208#p4208
This is what i think is the problem.
id the sound is to loud i think its the Color Wheel maybe its broken or louse you need to check and see that you color wheel is not making the loud sound!
Good Luck on fixing your TV
Mar 10, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Showcase freezer fan motor makes constant clicking noise
Is the noise clicking consistantly?or just on again off again?Yes there may be a faulty motor.Try removing the wires and tape them up then run the unit if there is still noise need more info .And to let you know yes they can be made into a low quality air compressor:) hope i helped :)
May 11, 2009 | Frigidaire FRS26R4A Side by Side...
Loud Knocking
If the noise is not coming from the fan as Buffalo suggests, it is most likely the expansion and contraction of the heat exchanger. The old school way to lessen the noise of expansion is to bank the combustion chamber with a hammer. I don't recommend it today because the metal is so thin (thus all the noise) and you may damage it. You will get used to it and the noise may soften the more it is used. You will never get it to stop.
Dec 04, 2007 | Williams 3003622 Ceramic Wall Mounted...
Dell OptiPlex 330 Desktop Desktop Computer  Logo
18 people viewed this question
Alun Cox
