Question about Arrow Plier-Type Stapler, Large Capacity - P35
Staples stuck after stapling once - Arrow Plier-Type Stapler, Large Capacity - P35
sbg_ofp
  • 10 Answers
SOURCE: Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Posted on Nov 05, 2008
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
  • 384 Answers
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Posted on Jul 07, 2009
  • 94 Answers
SOURCE: How to load Staples ?
at the rear of gun there is a small door, press in and down at the same time , it should come out ,there is a spring attached to it as well.
Posted on Apr 25, 2010
SOURCE: how to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Posted on Jan 07, 2011
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
My stapler won't staple.
You may have a stable stuck in their,remove all staples and see if one is stuck in their.
Jul 20, 2015 | Tools & Hardware - Others
How do I get the one-touch handle to work/rise up automatically again?
look under it and see if a staple is STUCK if so pry it out and it should work fine
May 28, 2015 | Staples One Touch High Capacity Stapler
Handle stuck in locked position
One of the screws - furthest away from where the staples exit - has a nut on it... Remove the nut, then - using pliers - back out the screw. When I did this, the spring returned, a bent staple fell out and once re-assembled I could use the stapler again (for a few turns). It seems like the stapler is VERY sensitive to bounce during the stapling, you must hold it very tight (and flat) to the material so that the staple doesn't jam inside the stapler. Lousy product.
Mar 16, 2013 | Powershot Tool Company PowerShot 5700KB...
Xerox Staple cartridge stuck
If the cartridge is stuck in the slide it is because there are still staples in the replaceable sleeve, if the whole slide is stuck in the finisher, you might open the panel over the staple unit and see if you have staples stuck that are causing you to not be able to remove the cartridge.
Oct 25, 2012 | Xerox 4110 4127 4112 4590 4595 Drum...
Not shooting the staples
Sounds as if you have got some staples stuck in the shoot.there is no safety lock.
Aug 17, 2012 | Tools & Hardware - Others
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
I think a staple is stuck and have lost the instruction book
I decided to leave it, as I no longer need the staple gun
Many Thaks
Oct 02, 2009 | Tools & Hardware - Others
Piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
Arrow Plier-Type Stapler, Large Capacity - P35 Logo
16 people viewed this question
Top Arrow Office Equipment & Supplies Experts
Lawrence Oravetz
pulsev2
gonaone
Level 1 Expert
Are you an Arrow Office Equipment and Supply Expert? Answer questions, earn points and help others
