Question about RCA TruFlat 27F520T 27" TV
I turn on my rca tv then i heard it start to fry then make some poping sound everything else was good with the tv what do you think is the prob
    Top Expert:
  • RCA Master
  • 74,118 Answers
Contact any service technician. The main power regulator circuit section to your TV need a through checking. This is not a work, that a user an do with ease. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Gopakumar Gopalan Google
Posted on Feb 13, 2014
2 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: RCA F27650 32" TV Problem
Hello ddw7321,
This sounds like it could be a malfunction in the High Voltage section of the TV. The shutdown circuit is switching on and preventing the TV from turning on. This might be due to an excessive amount of current flow possibly caused by a shorted turn in the Integrated High Voltage Transformer (IHVT), or a shorted Horizontal Output Transistor (HOT). To test this you will have to unplug the TV set, and with a multimeter set to resistance, measure the resistance from the collector of the HOT to ground, If it reads 0 ohms then that is the problem (a shorted HOT). The next test which is of the IHVT is a little difficult because it requires removing the IHVT and doing a ring test. At this point I would like to suggest that you take the TV to a repair shop, because these next test might be difficult for someone who does not know electronics, and if you have no knowledge of electronics you may do more damage then good.
With that being said:
Remove the HV anode of the IHVT connected to the CRT by first using a large flathead screwdriver connected with a clip lead to the ground of the TV, by sliding the screwdriver under the rubber cap and releasing the clips. Then unsolder the pins on the bottom of the IHVT using a soldering iron and a suction type desoldering pump. when the solder is removed , pull the IHVT from the circuit board. locating the main primary winding connect it to the device that you are using to perform your ring test (I use a Sencore LC-102), when it is connected do the ring test and it should have at least 10 rings to be considered good, any less then 10 and the IHVT is to be considered as bad.
I hope this helps.
Thank you,
Shuttle83
Posted on Oct 04, 2008
I hooked my battery up backwards now the ignition won't turn over when I turn the key. It also sounds like its not getting fuel
hooking up backwards basically fries everything first take the starter and get it tested you problly fried the solenoid but pray you didnt fried your igniton switch on the car and as for the fuel you most likley poped the fuse pray that it is the fuel beacuse a new fuel pump can cost ya a good amount
Jul 20, 2013 | Cars & Trucks
I have a 1993 36 inch RCA, model # P46151WK. TV was on and suddenly heard something pop and it started to smell like something burned inside. It wont turn on anymore.
You may have a fried horizontal output transistor and a defective flyback transformer. If indeed this set is 17 years old.......cheaper to replace him...sorry!
Mar 01, 2010 | RCA F32650 32" TV
Frys tvs .luckly they were old 13" tvs .dont have any more tvs that I would want to fry .this happened twice hooked to tv in travel trailer,turned on tv went out checked wall voltage 118 volts rca...
this could be your power brick being faulty and letting to much power through to the xbox and earthing it through the TV resulting in the TV frying.
try changing your AV cables from the xbox to TV and your power brick and leads going to the console
Jan 28, 2010 | Microsoft Xbox 360 Console
RCA model 27f52ot turns on and off randomly for a few seconds eac
Best solution take the tv aparts go to the small flat control board in the front on the bottom of the bazel(the frame).U know how to soldiers?Resoldier the power switch,If same prob.occur go the tv shop for repair.Ur tv have a short prob. with the ic chip or its parts that control that little board.Here another solution take all the electronic's equipments away from the tv,that solve the same waves(radio frequincies prob.) tries that solution first,some device will turn it self on, if have same frequincies use by the other devices,just like ur Automatic garage door open will open other people garge door if their control box on top their garage don't have ramdom codes function's modjulators.
Aug 21, 2009 | RCA TruFlat 27F520T 27" TV
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Sony Grand Wega No picture and no sound
i think its the colorwheel you heard go pop... replace it and you should be good to go
Jan 25, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
My tv want come on;
If your set is rear projection set you have a bad flyback transfromer or high voltage trippler is bad .
Jan 26, 2008 | RCA P52928 52" Rear Projection Television
Changing the lens rca 52 in projection tv
ricki your bulbs are prob. ok you have a vertical or video prob these tv's are easy to repair by a qualified repairman...john
Sep 11, 2007 | RCA P52926 52" Rear Projection Television
RCA TruFlat  27F520T 27" TV Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
