Question about Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
Dcp-j315 paper jamp problem - Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
How do i troubleshoot dcp-j315 showing machine error 46?
try 1 then 2
1. reset counters of ink absorber or flushing boxes (press the menu key on the touch panel and the black start (mono start) key on the control panel. next press the scan key four times. displays
"maintenance". press the 8 and 0 keys in this order in the initial stage of the maintenance mode. (for
models without numerical keypad, enter 8 and 0 using the up and down arrow keys, and ok .)
press the black start (mono start) key several times until the purge (or flushing) count appears on the lcd.
press the 2, 7, 8, and 3 keys in this order to reset the purge (or flushing) count. and ok keys.)
press the stop/exit key to return to the initial stage of the maintenance mode.
2. the ink absorber or flushing boxes are full. replace them
Oct 01, 2014 | Brother DCP-J315W Inkjet Multifunction...
Paper jamp
take the paper tray out,near the pickup roller you will see a black sensor arm,push with finger to see if the arm goes up.if not senor arm require replacing.
Jun 21, 2009 | Samsung CLP 300 Laser Printer
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Canono ir2016 system error E007
Fixing film has been displaced e007
Having too much paper in the paper tray will cause your printer to have more frequent paper jams and double printing. Make sure you fill the paper to the fill line. I usually recommend going a little below line. I would also recommend that there is no paper from your previous jams still stuck in there. That will cause it to jam up as well.
Nov 30, 2008 | Canon CLC 1140 Copier
Error Code 5100
Carriage error. Paper or the print mechanism is blocked.
It could mean the rollers don't grip the paper, there is torn paper keeping the rollers from turning, the paper can't stick to the rollers etc.,
http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
Sep 01, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Paper Jam
Unplug printer check the paper loading tray something struck , small paper , coins, hair pin etc , printer can detect , message appear paper jamped.
Dec 05, 2007 | Lexmark E232 Laser Printer
Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Logo
24 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
