Question about Canon Office Equipment & Supplies
Ir2025 drun replace
Drawer 1 dont work
  • 26 Answers
Might be a problem with your paper pick-up roller from the drawer 1. Clean it or replace it.
You need to remove the drawer and then you can see the roller.
Posted on Feb 13, 2014
How can do reset ir2025
Between the LCD and Keypad No.4 there is Reset button which restores the standard settings of the machine.
Aug 07, 2014 | Canon Office Equipment & Supplies
DD603 model & top drawer totally dead, no lights but bottom drawer 100% Your thoughts plse.
possible causes
  • top drawer controller has lost power - replace power filter plate located at the base of dishwasher under bottom drawer controller
  • itself is faulty if you are getting some lights on the panel
  • thermal relay has tripped. It is located inside the heater element at the base of the drawer. The whole heater needs to be replaced.
Make sure the dishwasher is disconnected from the mains power supply when working on it
Jul 26, 2012 | Fisher and Paykel Dishwashers
Can't get front of cabinet to fit back into the drun
The drum actually sits on the felt to prevent the metal grinding against metal
Jun 03, 2012 | Whirlpool LER4634J Electric Dryer
I have the dish drawers which are leaking from a hose behind the system. I need to replace the hose but I dont know how to take the entire unit out and /or take a drawer out to get back there. Thanks, Brad
Are you sure it is a hose?
Remove the bottom drawer and you can see every thing .Here's the procedure. Very simple and clever design.
Pull bottom drawer out part way.
Look for a large slotted plastic "scew"on each side top corner.
Remove both with 1/4 turn.
You can now pull drawer all the way out ,lifting slightly as you go. It will disengage from rails.
Don't go too far as you'll see the "umbillical".
You can now actually see alot inside.
You can actually run the top drawer with bottom drawer out to watch for leaks,check hoses etc
There's a good chance your lids are leaking ,not hoses .To fix, replace lid actuaters while your in there.
Hope this helps
Aug 15, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Rocoh FT 4220 leaves a blank strip across every page that I try to copy. I have cleaned everything I could, but must have missed something. The blank strip is not always in the same location on the...
Clean the optical section(glass,mirrors,lems)Verify the paper dust on the edge of the cleaning blade,if the OPC drun scratched or the fusing hot roller scratched.Press the cleaning blade release lever down several times.Make a copy and stop the machine when the paper reaches the transport section.If the lines appear replace the OPC drum.After replacing the drum perform the Drun initial setting,Light Intensuty Adjusment,ADS voltage adjustment,Vsg adjustment.
Sep 25, 2009 | Ricoh FT3713 Copier
I HAVE A BROTHER MFC-8860DN AND AM SEEING A MESSAGE SAYING ... DRUN NEAR EMPTY... I JUST CHANGED THE DRUM AND STILL SEEING THE MESSAGE ... WHAT SHOULD I DO...
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 21, 2008 | Xerox Phaser 8400 Laser Printer
Paper
If the paper size tab inside the drawer is out of position, even by 1/8 inch, you will have this problem. Also, the drawer itself could have a flaky/broken paper indicator switch (shows how much paper is left). I have had both these issues. On the first, I just slid the adjuster back in to letter position. The second, however, took replacing the drawer.
Nov 18, 2008 | Brother HL 5140 Laser Printer
Drawer will not go in
This just happened, I found that if you (1) remove the drawer, (2) turn off machine and wait a bit, say a minute or so  (3) turn it back on and finally replace the drawer WITHOUT the grounds bucket it will (may?) reset itself.  Don't forget to replace the grounds bucket afterwards.
As mentioned this is because the flap gets out of sync, I believe I caused this by having too much powder in the powder container.
Feb 13, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
35 people viewed this question
old marine
old marine
