Question about Lenovo ThinkCentre M55e 9632 PC Desktop
ThinkCentre M55e 9632 front audio jumper - Lenovo ThinkCentre M55e 9632 PC Desktop
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
How do i find out which Lenovo model is my Desktop PC? Its a Lenovo ThinkCentre 9637-AA5.
1) Series:
It's a ThinkCentre M Series Desktop
2) Subseries:
ThinkCentre M55e
3) Machine Type:
9637
4) Model:
The Model Number will be right after ThinkCentre M55e-9637
It will be two numbers and a letter, or two letters and a number, or three letters.
Three characters. (symbol)
Some examples; 21B, 21H, 22U, 28s, 28y, B2F, B26, I2F, (i2F), I64, (i64), W2Y, W2Z, WJW, WJM
ThinkCentre M55e-9637-WJW
(Above is fictional. Just an example)
Regards,
joecoolvette
Sep 20, 2011 | Lenovo ThinkCentre M55e 9637 - Core 2 Duo...
Hi, excuse my poor english. How can I disable onboard video on a Lenovo M55e 9632AE2? Thanks in advance. Markus Brandl
There are two ways to disable the onboard video:
First Option:
When the machine boots up, watch for instructions such as "Press to enter setup, bios, configuration, ect." Within the BIOS setup should be an option to disable to onboard video. This can usually be found within an Integrated Chipset Features section or a Video section depending on your BIOS. Be careful though, messing with settings that you don't understand can affect your computer negatively.
Second Option:
Assuming you're disabling the onboard video because you have installed a video card, access the device manager by right-clicking "My Computer" and click Manage. Select the Device Manager on the navigation pane on the left, then expand the Display Adapters section. Right-click on your onboard graphics adapter and then click Disable and you're done!
May 25, 2011 | Lenovo ThinkCentre M55e 9632 PC Desktop
When i try to install the sound driver in thinkcnter m55e 9637 model at that time one problem is accurs "HDA is required and not found plz re-install the driver" i have win 7 os and i also try to other os...
high definition audio = HDA
i would restore the system to factory settings : simply use your recovery CDs to restore that unit to factory default settings
if you dont have the CD recovery, go here http://restoredisks.com/ -- it will cost money to retrive these CDs , but its inexpensive comparatively speaking
Oct 15, 2010 | Lenovo ThinkCentre M55e 9637 Desktop
Sound card doesn't work
Hi, Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Go to start button, control panel, system, hardware and select device manager. Click the + for your sound device and see if there are any problems, if so it will be highlighted with a yellow? right click your audio and update your driver. Or go to Google and search for the latest driver to download.
Hope this helps
Jul 14, 2010 | IBM Lenovo ThinkCentre M55e PC Desktop
No output of sound after plug in the speakers.
reinstall realtek HD audio manager from your motherboard driver disc.
May 22, 2010 | IBM Lenovo ThinkCentre M55e PC Desktop
Lenovo ThinkCentre M55e 9632 PC Desktop Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
