What are the advantages of cmos setup? - Computers & Internet
How to exit safe mode
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Apr 30, 2013 | E-Machines Computers & Internet
My desktop 4210 is in paused mode how do i fix it
Step 1:
Restart your computer During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys Acer: - Ctrl +Alt +Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc) Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 12, 2013 | Computers & Internet
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
Feb 05, 2013 | Dell Latitude D800 Notebook
Dead CMOS battery on an AST Advantage! Adventure 575
Most motherboards use a coin size 20mm dia, 3 volt lithium battery type CR2032.
Jan 22, 2013 | Computers & Internet
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
Sep 27, 2012 | Sun Blade 2500 PC Desktop
Reset CMOS on IBM 2847
  1. cmossave.jpgEnter CMOS setup.
  2. In CMOS setup look for an option to reset the CMOS values to the default setting or an option to load the fail-safe defaults. With many CMOS setup screens there will be a function key to do this; for example, the F5, F6, F9, F11, or F12 key like shown in the picture to the right. Other setups may actually list an option that you can arrow over to using the arrow keys and press Enter.
  3. When found and selected you'll likely be asked if you're sure you wish to load the defaults press Y for yes or arrow to the yes option.
  4. Once the default values have been set make sure to Save and Exit and not just exit.
May 14, 2012 | IBM Computers & Internet
How can i remove setup password ?
If you short the CMOS jumper on the motherboard , you can reset the setup password . Find the CMOS jumper near to the CMOS battery . If you can't find the jumper , just remove the CMOS battery and smps power cord . Wait 3 min and re insert the battery . Now check it will not ask setup password .
Thanks
Nov 28, 2011 | IBM NetVista PC Desktop
Hi.i want to learn how to format computer.help me
to format the pc you need to enable the boot to cdrom options on the cmos setup. if your not familiar with it follow this instructions:
TO GO TO CMOS SETUP 1. on power up repeatedly press the DEL button or F2(if your using a phoenix bios) 2. you will be directed to the cmos setup. under the setup menu find the BOOT OPTIONS(use the navigation instruction at the bottom of the screen to navigate your way through the cmos setup) 3. Under the boot options select on the 1st category CD-DVD drive.. on the 2nd catergory the hard dirve (Seagate, maxtor, hyundai etc) 4. then press F10 to save to cmos and exit.
After you have set the boot option, insert the windows cd on the cd drve and restart the computer. windows setup will then direct you to the installation process
You may also want to visit the microsoft tech hub (www.microsoft.com) to have some tips on how to format and install windows..
Apr 26, 2011 | Microsoft Computers & Internet
CMOS SETUP WRONG
Go into the bios setup and change it
Jan 22, 2009 | EliteGroup P4VMM2 V5.X Via P4M266A...
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
1. New hardware has been recently installed.
2. Error or confliction with settings in CMOS.
3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS.
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
