Question about Breville CBL10 BlendMaster Classic Work Top Blender
I need part CBL10 04
Hi I have this blender and the white plastic lock in wheel on the base of the jug cracked. The blender works perfectly and it is hardly used. Breville no longer have the part I need does anyone have one or do you need parts for your own. the condition of mine is too good to throw away.
bunnydawg
  • 5158 Answers
SOURCE: Lost Seal for Blender
I would suggest you contact the company at
http://www.breville.com.au/ (click on "what's on your mind") and let them know the problem... they should be able to direct you to a UK parts source or help you in some other way.
Posted on Mar 23, 2009
  • 10 Answers
SOURCE: Blender stops after about 2 seconds on every setting
correct - replacing the cord is suggested and simple.
Posted on Aug 04, 2009
pappapumpdaf
  • 635 Answers
SOURCE: grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
Posted on Mar 09, 2010
  • 10865 Answers
SOURCE: I need to acquire a glass jug for a breville BLR-3
Hello. The best route to go is to work directly with the manufacturer. here is their contact info
  • AskUs@BrevilleUSA.com
  • 1.866.BREVILLE (1.866.273.8455)
  • 8a to 5p Pacific Time
  • Posted on Mar 22, 2010
    SOURCE: Hi, I also need the glass part of the blender if that's possible? My 2 year old some how smashed mine on the floor :-(
    yes i do, i live in rockhampton
    Posted on Sep 23, 2012
    Can't remove glass jug from plastic base...........Used once.....not impressed....probably won't buy again
    The bottom of the plastic base has some grooves on it to grip it. Make sure you are turning the glass counterclockwise with respect to the base being below it.
    Jan 28, 2011 | Cuisinart SPB-7 SmartPower Work Top...
    I have been given a Kenwood BL300 blender. After using it to make breadcrumbs, I undid it somehow and now I can't get it back together. Can't remember if the blade goes straight into the base or the jug,...
    You need to unfasten the white base from the clear jug, then the rotating blade will sit inside the white base, with the blade facing upwards. The white rubber flange goes in next. Then screw the assembled base back into the clear jug. The jug should then fit on to the stand.
    Dec 08, 2010 | Kenwood BL300 SingleSpeed Blender
    Broken glass jug on kitchenaid blender model 5ksb2aer4
    Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
    The left hand thread ensures the blade assembly does not unscrew during normal blender use.
    Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
    Grip the wing nut with your other hand and unscrew it CLOCKWISE.
    Remove the wing nut. You can now remove the blade from the plastic base.
    Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
    Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
    Do not over tighten the wing nut; you may have to replace your jug again at some point.
    Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
    I have a BL1900 and the black plastic wheel on the base cracked and broke into a million pieces. It is the part that the glass liquidizer sits on - the collar from the liquidizer 'locks' onto the this...
    You can order this part Black and Decker Blender Base Collar Ring BL5000-11
    I also had the ring crack and ordered another one. It cracked after just a couple uses. So, even though you can get the replacement part, I'd suggest tossing the whole thing in the garbage and buying a different brand.
    May 26, 2009 | Black & Decker BL1900R Blender
    Seal/Gasket missing on Braun Blender
    Hi. There's only one common blender made by Braun, which has a triangular jug in either glass or plastic, but the locking ring and gasket are the same. It'd be a 4184, either a MX2000 or MX2050.
    Auckland has a Service Centre:
    0.gif Key Service Ltd
    7D Echelon Place, East Tamaki, Manukau City Auckland
    P.O. Box: 38569 Howick
    Manukau City
    Phone Country Code: +64
    Phone: 09-916 0960
    Fax: 09-916 0970
    Service for: All products
    Otherwise, you can locate Service Centres in Australia.
    Apr 13, 2009 | Braun MX 2050 PowerMax Work Top Blender
    I had to call Black and Decker directly 800-231-9786 to order the part (called the "collar"). It was $14.95 w/ shipping and handling!! Seems pretty steep for a piece of plastic.
    May 04, 2008 | Black & Decker BL5900 ProBlend Work Top...
    Replacement glass jug?
    I will buy the blade set from you? I will return....
    Nov 14, 2007 | Bosch MMB2000 Work Top Blender
    The plastic base of the glass jug is broken, need repacement.
    I used a 4" stainless steel hose clamp as ours was cracked but not in pieces. So far it has worked.
    Nov 11, 2007 | Bosch MMB2000 Work Top Blender
    Breville CBL10 BlendMaster Classic Work Top Blender Logo
    56 people viewed this question
    Top Breville Blenders Experts
    Mike
    Joseph Hoffmann
    Are you a Breville Blender Expert? Answer questions, earn points and help others
