Question about Powermatic 63 10" Artisans Table Saw Op Part Manual
I need to rewire my Powermatic 63a from 220v to 115v.
There is no help in the manual that I have found. Their website doesn't even acknowledge this model anymore, and I can't find any help in any previous forums. Does anyone know where I can find this information?
4 Suggested Answers
  • 4088 Answers
SOURCE: Belt for Powermatic 15" Planer (Planer Model M-0460213)
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Posted on Sep 07, 2009
al_kupchella
  • 843 Answers
SOURCE: Need a chuck key for model 1140b,f powermatic
There are only a few sizes of chuck key. Easiest thing to do is first find a drill bit that fits in the hole where the key goes to determine the size of the pin on the end of the key. (Use the back end of the drill bit.) Then take any other chuck key you have and see how closely it fits or doesn't fit - just as a reference. Take the reference chuck key and the drill bit with you to Sears or any place that sells a good assortment of tools. You will probably be able to determine the correct size key from what they have available very easily. Good luck, Al K
Posted on Mar 14, 2011
SOURCE: how to assemble a powermatic powerfeeder model number pf-31 to a tablesaw sawstop model number ics53230?
As far as mounting, you may have to drill some holes in your table. Or get the quick mount from Grizzly Ind. There should be a gap between a couple of the rollers. This is where the blade sits. Dont let the blade cut into the rollers though. Set it at a very slight angle to keep the wood against the fence. Try it without cutting wood first. Hope this helps, and good luck!
Posted on Sep 15, 2012
Will a Packard bell i media desktop run on united states power ?or is it strictly designed to run on European power ?
Here in the US, and with more than 20 years experience as a computer tech I would venture to answer that almost any computer should work almost anywhere in the world.
You only need to look at the input voltage and make certain the power supply is set to match the line voltage supplied where you are. Standard electricity in Europe is 115v or 220v @ 50hz and in the US it is 115v (almost universally) or 220v (rarely) @ 60hz. The biggest difference is the ac frequency used but for computer power supplies that is immaterial.
A computer power supply converts the ac input power to regulated and filtered 3.3v, 5v, and 12v dc so the ac frequency does not have any affect on the filtered dc output that actually operates the computer. Almost all power supplies have a voltage selector switch near the power cord plug on the back of the computer to choose 115v or 220v. Newer power supplies are designed to be auto selecting on input voltage so even that manual selection is no longer required.
You likely will need a different power cord since the shape of the prongs on power outlets in Europe is always different than here in the US. If I remember correctly from my time in Europe that even varies by country there.
As long as you keep in mind the possible different voltages and the different prong shape and arrangements for the ac power source your packard bell computer should work well here in the US.
Absolute worst case scenario would be that if the power supply already installed in your PC is extremely low quality and was designed to use only one input voltage then it is possible you may need to replace the power supply with one that is designed to be used anywhere.
Mar 02, 2017 | Packard Bell Computers & Internet
How do I wire a cutler hammer a10ago for 115 volt
I'm going to take a guess and say you are dropping a 230v motor down to a 115v motor.
If the original motor on your equipment was 3 phase, then you need to change motors.
On the other hand, if the equipment had a 230v single phase and you are switching the motor wires so you can plug the equipment into an available 115v outlet, then I would suggest reconsidering. I would recommend running a 220v service line to your equipment instead. It will save on your electric bill and the motor will last longer. A 115v motor pulls twice as much amperage as the same motor running on 230v. (it may even be too much for the 115v outlet you are planing on using) Your variable rate electric meter will tell your power company to up the rate you pay per kilowatt-hour when you use power at a lower voltage but higher amperage rate.
That said, you need to make sure that the coil in your fancy starter switch is a 115v coil. (it probably is) When you hook up the 115v plug, you need to make sure that the black wire in the Starter Switch is the wire that the switch borrows power from to kick start the magnet that keeps the circuit closed. Beyond that , you probably don't have to do anything in the switch. If there's a red wire, you can just disconnect it and tape it off and do the same in the plug.
If the a10ago's function is a mystery, it will help to understand how it works:
Basically, the contactor has three switches side by side. Where the power comes into the box, there's what looks like a lot of extra screws. That's where the thermal protector is (circuit breaker) that will protect your motor at the proper level designed for the motor. The switch has a spring that holds it open so the motor won't run. But there's an electro magnet that can hold the circuit closed. That magnet is only energized when the switch is closed because even though one of its leads is connected to the hot side of the switch, the other lead is connected past the contactor which has no power when the switch is off.
Your 'START' push button momentarily energizes the coil (or maybe it just overpowers the spring and physically pushes the switch closed). The switch closes and the motor runs and keeps running because the coil is energized. Your 'STOP' button momentarily cuts current to the coil and the switch pops open.
The purpose of this contraption is:
1. It contains a circuit breaker suited for just the motor that is running, not for every load on the circuit.
2. It has contacts that will wear much longer than a standard switch.
3. If your shop loses power with the motor running and then the power comes back on later, your motor wont start running by itself. It will wait until you press the 'START' button.
Oct 09, 2014 | Saws
What belt(brand/numbers)to replace the one on a Powermatic Artisan 63A Table Saw?
Probably a long out of date question but my suggestion is to purchase a link style belt to replace the old hard drive belt that comes with the saw. It'll deliver more power to the blade, run quieter and work better. I also recommend replacing the drive pulleys while you're at it. Get a couple of balance ones.
You can get a link belt at Rockler or other woodworking outlets.
http://www.rockler.com/1-2-power-twist-plus-link-v-belt
Jun 19, 2014 | Powermatic Saws
How to assemble a powermatic powerfeeder model number pf-31 to a tablesaw sawstop model number ics53230?
Sep 11, 2012 | Powermatic Pf-31 Powerfeeder, 1Hp, 1Ph,...
On our 6250 Generator, the breaker pops continually. This happens when running only lights on our RV, or when using it to run a water pump. It will run just fine and then the sound changes and the...
You will have more available power (and use a different larger breaker already on your generator) if you use the 220 plug instead of the 115v plugs. Have an electrician make you an breakout box separating the 220v plug into two 115v outlets. Or your can replace the push button breakers with better quality 25 amp. Problem is that the 115v receptacles are probably 15 amp. Other solution is to try a 220v pump instead of 115v (more efficient draws less amps). Good luck
Sep 02, 2011 | Coleman Powermate Premium Plus 6250W...
I have a Powermatic model 66 table saw that hums (at the starter switch not motor ) when I turn it on. I just rewired after moving but have checked all connectors with multimeter and I think it is wired...
I am thinking that you have mistakenly crossed 2 or more wires, hopefully you wrote yourself a wiring diagram or there is one inside the motor cover. I don't know if I can find a wiring schematic for this tool. If you still have the owners manual look in there for initial setup and see if they provided one. If you need more help let me know and I will do what I can.
Mar 02, 2011 | Powermatic 1660802K Model 66 Special...
I have a Pelco ES30CBW35. Rewire the 230V/115V switch and transfo
this manual should help
  1. [PDF] Pelco EH3500 Series Environmental Enclosure_service manual
go here and down load it you'll need adobe reader to view it but, you can get it for free. Best of lock Rich.
Oct 23, 2009 | Pelco ES3012 5MLZ30W Esprit High Res Black...
Kemore ac model 75151 compressor wont come on any ideas
If you're main power is 115v and the capacitor is rated 220v it could work. But if the other way around the capacitor would melt or blown if use.
May 25, 2009 | Kenmore 75085 Air Conditioner
10,000 watt generator 220 plug doesn't work
Most generators have several circuits incorporated within the windings. There are usually two 115v windings, one or two windings that produce power and sensing voltage for the regulator that supplies power to the armature (produces magnetic force) and sometimes a 12v winding to supply power to charge the battery. The two 115v windings power one 115v plug each and together power the 220v plug. Each outlet has a breaker and or ground fault. Since the 115v plugs are working indicates that the 220v plug must have an open/broken wire or faulty breaker. Easy to check, however you must open cover to wiring compartment and trace wires. Should be easy fix. You do not have to start engine to find broken wire. Use ohm meter instead. With engine off, Insert probes into 115v plug and obtain ohm reading. Then insert probes into second 115v plug and obtain similar reading. Look for same reading at the 220v plug (remember 2 circuits of 115v, ground and neutral). Good luck with your repair and email if you have other question.
May 09, 2009 | Electrical Supplies
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Powermatic 63 10" Artisans Table Saw Op Part Manual Logo
85 people viewed this question
Top Powermatic Saws Experts
80stech
Dennis Key
Dennis Key
Ivan
Ivan
Level 1 Expert
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
