Question about Advantech TPC-1570H-P2E: TPC Series 15" Pentium M Touch Panel Computer
TPC-1570H connect to laptop - Advantech TPC-1570H-P2E: TPC Series 15" Pentium M Touch Panel Computer
I have 97 firebird 3800 automatic i had to replace a bad tpc the engine is running great but its not shifting well at all .how do i reset the emc/smc and or adjust the tpc?its shifting at 4000
Look for a vacuum leak at the modulator and the other end of the line where it picks up vacuum from the intake manifold. Cracked or missing hoses will cause your shift problem.
Apr 06, 2018 | Cars & Trucks
I'm trying to reset an 1070 TPC supra pad tablet it has in old password to get into and I do not know it. Can you help???
Try to connect it to a computer with the tablets website and erase the whole table, this may be the only way, sorry you would loose all you stuff... hope this helps
Sep 07, 2017 | Tablets & eReaders
Ineed a turntable belt for tpc-hd 12
Fixya is not a buying service. Try an internet search for turntable belts.
Oct 17, 2016 | Audio Players & Recorders
Why does my car idle at 2500rpms
CHECK IF ANYTHING GOT STACK,CLEAN THROTTLE BODY.CHECK ALL CONNECTION,YOU COULD BET THE PINS!
May 21, 2016 | Cars & Trucks
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
May 15, 2012 | Audio Players & Recorders
Why would my rpm jump and make my car seem to jolt forward? i was told it could be the camshaft sensor,or the throttle position sensor...any suggestions?
The TPC ( throttle position control) or the IAC (Idle Air Control) is defective. The TPC is bolted on behind throttle control. Takes very small hands to remove it. Symtoms are the engine will speed up to ~ 2000 or more RPM when the gas peddle is released. Almost like the Toyota problem. But you can apply the brakes to slow it down or stop.
Jan 10, 2011 | 2001 Oldsmobile Alero
My Thomas Pecconi TPC MSE 800 cassete player stopped working - please advise troubleshooting tips
A similar unit arrived for servicing. In this case, a poor solder job at the point where the red and black wires connect to the motor was the problem.
Jul 08, 2009 | Kaito KA1916 Shelf System
Advantech TPC-1260T touchscreen pc blowing 5 amp supply fuse, after being powered down
I dont know how old the touch screen is. If its new send it back if not get a qualified electrician to take a look.
Mar 31, 2009 | Advantech TPC Series 5.7? Touch Panel...
Advantech TPC-1570H-P2E: TPC Series 15" Pentium M Touch Panel Computer Logo
18 people viewed this question
Top Advantech Computers & Internet Experts
Rajendra Singh
Rajendra Singh
Stan Ford
Mishan Kasiparsad
Are you an Advantech Computer and Internet Expert? Answer questions, earn points and help others
