Question about Denso 1997 Jeep Cherokee Sport 4.0L Remanufactured Alternator
Dashboard lights and gear shift lights and both tail lights not working
No dashboard lights no gear shift lights and both taillights are all out
  • 37 Answers
Have you installed a radio, trailer lights, or did something with the wiring? If you did you probably ran a hot wire into the grounding and caused the fuse to blow. If you haven't messed with the wiring you probably still have a blown fuse. Pull the fuses out and hold them up towards the light and see if the thin wire inside the plastic fuse is burned in two.
Posted on Feb 16, 2014
Brake lights won't work when i have my tail light fuse in. if it is out blinkers and brake light work but no taillight
check the earth hasn't corroded of the tail light maybe take a new wire to earth ,that is the frame
Feb 14, 2013 | 2005 Honda CBR 600 RR
Dashboard lights and taillights won't turn on
I was told that it is the rheostat, go to Advanced or O'Reilly's.
Feb 03, 2010 | 1997 Dodge Dakota
My Headlights, taillights, and lights on my dashboard/gear shift do not come on, the only lights that work ar the brights!
Fuses. Check those in the interior fuse box (left kick panel, below the dash--fuse chart on the cover) and those in the engine compartment fuse box (far upper left as you face the car). If, after you replace anything that has blown, it blows again, that would suggest a short somewhere in the system, or a bad light switch.
Hope this is of some help.
Sep 27, 2009 | 1992 Honda Accord
Taillights and Dashboard lights dont work anymore
the simpliest answer would be to check the fuses, they are located under your dashboard. View owner's manual to find out which fuse run which circuit. If that isn't the problem its more likely an electrical short or the bulbs need changing.Hope this helps.
Good Luck =)
May 20, 2009 | 1991 Oldsmobile Cutlass Ciera
Location of taillight relay
Try to find the relay underneath the dashboard.
Apr 17, 2009 | Toyota Pickup Cars & Trucks
Tail lights not working
you have a bad headlight switch or a bad conection at the headlight switch
Mar 16, 2009 | 1995 Pontiac Grand Am
Headlights no Taillights
switch burned up due to a short in the tail light wire
Feb 18, 2009 | 1989 GMC K1500
Tail lights and dash lights
You'll have to read through your owners manual. For some time Auto makers have been putting your taillights on the same fuse as your dash lights as an automatic indicator that they are out. I would read through your owners manual and decided where and what fuse will supply power to the taillights and dash lights. If indeed all fuses in connection with the dash lights are good I would suspect the automatic starter.
Nov 29, 2008 | 2003 Ford Focus
Denso 1997 Jeep Cherokee Sport 4.0L Remanufactured Alternator Logo
Top Denso Electrical Supplies Experts
Lawrence Oravetz
wadingriver
wadingriver
pontelemon
pontelemon
Are you a Denso Electrical Supply Expert? Answer questions, earn points and help others
