Question about Cell Phones
I cant open my phone
I can not open my phone, hung .
Always hung my htc one x
Hello My Dear Friend::"::
mY Dear:
First:
restore your Phone Settings
IF problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Jan 21, 2013 | HTC One X Quad-core 1.5 Ghz 8mp 4.7" Lcd...
My n76 is hung and shutdown
Hi there! If your N76 hungged and shutdown automatically, it could either be that many application is opened and the phone wasn't able to handle it. Try to remove the battery and put it back in again then turn on your phone. Usually, by doing that your phone should have no problem opening. If it doesn't worked, remove the casing and then manually press the switch to on. Make sure that the battery is charged. If again it doesn't work, bring now your phone to the nearest Nokia center for them to diagnose what went wrong with your product. Hope I had helped you on your problem!
Mar 25, 2011 | Nokia N76 Cellular Phone
Why my nokia 6680 did hung when i opened some games and apps? And i cant open the files in the gallery but i opened it from file maneger? And my 1gb memory card says that mem. Card currupted?
Yes , your memory card has some files which are corrupt and must be removed off. So take the card out and if your PC is well protected , put it into the card reader and scan, remove all files and format the card, then reinstall the files which are good ones.
This must be put back to the phone and the phone having a reset with the battery taken out must be switched on.
Dec 04, 2010 | Nokia 6680 Cellular Phone
Phone stuck in wlan and cant dial out
Unfortunately most of these phones are not manufactured by a foolproof tested software and hence many of them work well till the phone hung or got a malware inside. In the first place these phones do not have backing of a service network and those who got them at such low prices did take the risk of a loss.If the phone cannot be reset to factory setting then if is obvious that the software is hung and needs a reinstallation. Try to find if there is any source/ local service centre who has the software for the model to be downloaded but most of the time these phones are though to be good as long as they last. Wish you luck. Good day
Jul 26, 2010 | Computers & Internet
Mobile got hung up
pls flash u r mobile once and proble will solve
Nov 19, 2008 | Nokia 2600
My N95 cellfon hung upon viewing songs, picture and images!!
hi there OWEE hope this will work for you. its a software problem
here's the tricks:
backup contacts first. then
power off the phone first then PRESS and HOLD
"CALL KEY" + "* KEY" + "3 KEY" then power on the phone just hold and wait till NOKIA LOGO appears then release. finish, phone will be ok. you will know that you successfully format the phone cuz' all your data form the phone will be back to normal.
ok!
peace!
Mar 28, 2008 | Nokia N95 Cellular Phone
My motorola V3 still hungs up!
You my friend need to have your phone flashed. Its very easy to do. Bring it to a local service center, and they should be able to do it on the spot. If you cant find a service center in your area, check my profile, and we will be able to help you
Jan 23, 2008 | Motorola Mobility RAZR V3c Cellular Phone
My motorola v3x problem
have the flexcable replaced and also have the firmware reflashed.
Oct 02, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
