Question about Kenmore Elite HE4 Electric Dryer
Get dead mouse smell out of dryer - Kenmore Elite HE4 Electric Dryer
Smell in dryer
take the dryer appart and clean it good
Mar 15, 2014 | Fisher and Paykel Dryers
Odor
if you have a bad odor,pull off the vent line from the back and see if an animal is dead there,i've found dead birds,mice and a possum,in the blower wheel of some dryers,they get in from the outside hood,once they get into the vent line and slide down they can't climb back out or if the dryer is running the wheel does a job on them.also if you had some painting or staining done this also can make the dryer smell bad.this is going by what i've found when someone complains about an odor in the dryer.hope this helps,one more thing if the motor is overheating from the dryer not being cleaned out it could have like a shellac smell,you might have to take the dryer apart to see what's stinking or it could be something near the dryer,when the air is heated in the dryer it makes the smell worse but if you find waht is causing it and remove it the smell will go away,if it is from a dead animal you can wash down the area with soapy water,you don't want to use anything with a strong smell because your clothes will smell of that when the dryer heats up.what does it smell like?
Apr 13, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
Dryer is not drying- wet lint in the filter
Maybe you have a dead animal, (mouse,rat etc) inside of unit. They could have died whilst chewing the wiring, hence the no heat problem. Take off the panel on the back of unit or tip it on it's side. You should be able to see the inner workings and anything else. If not, buy a new dryer, this one must be costing heaps to run.
Dec 14, 2011 | Dryers
2010 Equinox - Bad smell
it is common to get mice or? in the blower motor, you have to drop the blower motor out from under the dash? and check for debris
Jul 31, 2010 | 2009 Chevrolet Equinox
Bad odor from dryer
A dead mouse would have crawled up fro the bottom. Carefully tip the unit back and see if you have an unexpected guest.
Feb 16, 2010 | Maytag Dryers
My drier smells like a animal has died when heated up.
You will have to diss-assemble the dryer to look for the cause. I have run into that problem before, and found that a mouse electricuted himself by contacting the exposed wire terminals on the motor. When the motor warmed up, the dead animal smell was there. There are a lot of areas where a mouse could come in contact with live voltage and end up dead on an area which heats up, like near the heating element.
Jan 26, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Bad smell inside dryer
you might want to vacum the lint filter and the all the fan blower area some thing in the dryer is dead .
May 10, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
