Question about DeLonghi 6707E Oil Filled Radiator Heater
Oil heater, not working
Electrical problem
    New Friend:
    Problem Solver:
  • 15 Answers
Contact De'Longhi customer service.
Posted on Nov 29, 2014
Tip
Oil Filled Radiator Heater Leaking
<p>A very common and increasing popular source of <b>supplemental heat</b> in the last few years has been the <b>oil filled electric radiator. </b> <br /> <p>These <b>radiator heaters</b> are filled with an oil that circulates through the fins of the heater and is heated by <b>electric heating elements</b>. The result is a steady even type of heat that has a lower surface temperature then many <b>space heaters</b>, making them a great way to get <b>supplement heating</b> into a room when you have pets, small children or combustibles near by.<br /> <p><br /> <br /> <p>One of the big questions that comes up with these <b>oil filled heaters</b> is what to do if they start to leak. The answer is that if the<b> oil heater</b> starts to leak then it is no good anymore and needs to be disposed of. These<b> heaters are filled with oil</b> at the factory and then are sealed tightly. Because of this there is no need to ever <b>refill the heater with oil</b> again. The heaters are sealed with the proper oil inside for the <b>best heating efficiency. </b> <br /> <p><br /> <br /> <p>So what this means is that if you have one of these <b>oil filled radiator heaters, </b>you will never have any <b>maintenance</b> or worries about <b>adding oil to the heater</b>. But if there ever is a leak then the heater is also no good and will need to be throw out and replaced. Very few of these <b>oil filled heat units</b> ever leak, but as is always the case there are always some that do.<br /> <p><br /> <br /> <p>A word of caution about heating efficiency. Always remember that when <b>heating with electricity</b>, the <b>laws of physics</b> always apply. <b>For every 1 KW of electric you will only ever get 3415 BTU's of heat.</b><br /> <p>There is no way to get any more or any less than that, so if anyone tries to tell you that their electric heater is more efficient then the next one they are not telling the truth.<br /> <p><br /> <br /> <p><br /> <br />
on Jan 12, 2011 | Heating & Cooling
Tip
How does circuit breaker work?
In the circuit breaker there are two electrodes with space some distance.
There are many types of circuit breaker air blast,oil C.B, vacuum C.B etc.
Most probably oil circuit breaker is used. In the OCB, the transformer oil fill.
And these electrodes are submerge.
Now when the electricity flows from one terminal to another terminal, the arc is developed between terminals end inside the circuit breaker. This arc is quenched by transformer oil.And the electricity flows without any fault.
on Mar 04, 2010 | Bosch PowerStar AE125 AE125 Whole House...
KSD301
Try Grainger - snap disc controls.
Also, see my post, in response to "The heater does not work when switched on I have", under this same topic, 'Problem with: Lakewood Oil-Filled Electric Radiator Heater'.
Nov 07, 2012 | Lakewood Oil-Filled Electric Radiator...
Action-Aire AA150 Oil Filled Electric Heater. I am wanting to use this heater but I have two questions: firstly, there are two control buttons (with a light indicator on them) do i need to put on both for...
Oil in these heaters is not supposed to sizzle. So, I don't think it's the oil. Something else is probably making the sizzling noise and that's what concerns me. As this type of heater literally makes no noise. What you hear may be a short in the wiring of the heater. In which case, it's unsafe to use.
You didn't mention if the heater is new or that you've had it for sometime, but in either case, I would recommend not using it. If it's new, then it's still under warranty and you have some recourse. Check your Owners Manual for details on how to handle this as a warranty issue.
Feb 17, 2011 | Action-Aire AA150 Oil Filled Electric...
My black and decker oil radiator has gone dead all of a sudden
Have you check the electric receptacle it's plugged into, to see if it's still functioning. Do this either with test leads or by plugging in another electric appliance. If it's not working check your homes circuit breaker panel for a tripped breaker. If you find that's the case, make sure nothing is plugged into the receptacle and reset the tripped breaker. Plug your heater back into that receptacle and see if it trips the breaker. If it does, something in your heater is either overheating or there is an electrical short. In either case, buy a new heater.
Feb 15, 2011 | Black & Decker BDOH100 Oil Filled Radiator...
My lakewood oil-filled radiator heater has a smell of oil? or something. What is it and is it dangerous. Could it be electrical?
The heater is filled with oil and it is leaking....you will need to dispose of it and buy a new one... it is not repairable...
heatman101
Jan 04, 2011 | Lakewood Oil-Filled Electric Radiator...
Where do you refill the oil at
Oil heaters are not meant to be refilled. The oil is inside the heater already. If you need to add oil, the heater is defective. Do not use it.
Dec 16, 2008 | Lakewood Oil-Filled Electric Radiator...
DeLonghi 6707E Oil Filled Radiator Heater Logo
326 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
