Question about Rhino Outdoors Rhino Lid Camcorder
When I plug in my lidcam the light is green and never turns red.
Will not take a charge. And computer dose not pick it up when I plug it in.
What color is the light suppose to be when my pyle pro pwma600 pa speaker is charging suppose to be green or red?
Hi,normaly the green light says that the battery is fully charged,so if its red it might be that its charging but not fully charged,but saying that if it dose not charge after some time then the red light can mean its not charging,just food for thought,all the best.
Oct 02, 2015 | Cars & Trucks
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
I've been charhing the battery for 48 hours and no charge! any answers?
Kw How old are the batteries and have they been sitting up for a long time? If this is the case the charger cannot pick up really low batteries and charging them for 48 hours won't help. Unfortunately you have to get 2 new batteries. Your chair requires 2 U1 batteries. Now if the batteries are fairly new and when you plug the charger into the joystick you should be getting a red light and a yellow light on the charger. When fully charged the yellow light turns green. If you have both lights and it never turns green bad batteries if no lights or just the power light bad charger, If you have a digital voltmeter you can set it on 200 volts dc and place the leads in the two outter charger plug holes on the joystick. It should read the battery voltage fully charged 25-27 volts HOPE THIS HELPS
Sep 06, 2010 | NRS Hoveround MPV 5 - Used Power...
Red light turns on and off while charging e-reader 600
Okay Plug It In And Let The Red Light Turn Off By Itself Then Get A Tooth Pick Or Any Item That Will Go In The Reset Hole Then Pug it In Again. The Red Light Will Still Be On But After Five Minutes Unplug It Turn It On The Light Will Be Yellow Then Turn On .
Jun 07, 2010 | Sony E-reader Portable E-book MP3 Player
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
My xbox controllers will not charge with the plug in kit. The light turns red, then either immediately green, or it starts to blink red-off-red-off.
I had the same problem. The Battery pack on mine was dead for a long time as i havent touched my Xbox 360 in a while. So
SOLUTION
Step 1. Plug the play and charge cord into the controller
Step 2. If Light turns green within a minute or so, Unplug the play and charge cord and go to Step 1 (Repeating this process until the light stays red on the play and charge cord (3-10 times))
Oct 08, 2009 | Microsoft Xbox 360 Controller
My 24280 dig. Wont charge
the pc function means that it is connected to your computer this is good because now you should be able to upload pics and ect...the red light is simply to show its charge level and is always on when plugged in to computer also there should be a switch on the side to change from camera to charge if its on charge and the light is red then its carging and it will turn green when its done.
Jun 16, 2009 | Sakar 24280/24282 Digital Camera
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Rhino Outdoors Rhino Lid Camcorder Logo
94 people viewed this question
Top Rhino Outdoors Video Cameras Experts
Are you a Rhino Outdoors Video Camera Expert? Answer questions, earn points and help others
