Question about Arctic Start Compustar AR600S CS-600S
Compustar Arctic Start AR600S (CS-600S)
Wires
I have a 2013 Honda Accord with push start and ever time i unlock the car and open the door after it is remote started it shuts off. Is there a fix for this?
Yes, you must have the remote start reprogrammed, probably can only be done at dealership if factory or by the installer if aftermarket.
Jan 22, 2016 | Honda Cars & Trucks
Pulled the plug wire off the right cylinder and it killed the engine
Electrical Diagnosis for Arctic Cats - YouTube
? 9:58
https://www.youtube.com/watch?v=iwwl4LPyOCY
Dec 29, 2009 - Uploaded by BlaineDP
When in the "OFF" position the switch will ground the ignition wireto the chassis effectively "grounding out" the ignition systemkilling the spark. ... becomes disconnected or if a wire gets cut then the switch will no longer turn off the engine. ... Testing a stator in a snowmobile Arctic cat - Duration: 3:25.
CAT AS NO SPARK!! - American Snowmobiler Magazine ...
cs.amsnow.com > ... > Forums > Manufacturers > Arctic Cat snowmobiles
If the connection to any switch; key, kill, tether, throttle safety switch, etc.. is ... Some older model Arctic Cats have the ground up closer to the handle bars on ... Here is a general rule of thumb for putting spark plug wires on which cylinder for Cats: ... Pulledthe ECU cover off and found some corrosion; I had a 580 that did not ...
Jan 16, 2016 | ATVs
My remote start quit working all of a sudden. The lights and everything comes on like its supposed to but it doesn't start. The remote still locks and unlocks
My Remote Car Starter Stopped Working! - DON'T PANIC!
www.mobileedgeonline.com > Remote Car Starters
This time of the year rarely a week goes by that we don't get a call from someone stating that their remote car starter stopped working. Nearly every call is the ...
So Your Remote Starter Stopped Working.... Just Relax!
www.wssdriveeasy.com/remote-starter-stopped-working/
Sep 29, 2013 - You press the button on a cold Winter day to find that your remote starter stopped working! Take a deep breath. It is probably something very ...
My remote starter is not working, how do I fix this? - Compustar
https://support.compustar.com/.../202533874-My-remote-starter-is-not-w...
When your vehicle's remote start stops functioning the solution can change depending on each situation. The Compustar remote will not...
Remote Starter Won't Start - YouTube
? 1:02
https://www.youtube.com/watch?v=EuHu2VFx0ks
Nov 4, 2012 - Uploaded by daniluchison
Remote controls sends signal to Remote Starter but after a few 'clicks' it won't start the ... 04-08 Pontiac ...
remote start problems - YouTube
Jan 14, 2016 | Cars & Trucks
How do I reprogram my key bob
Remote Programming Troubleshooting Guide - Compustar
https://support.compustar.com/.../202839770-Remote-Programming-Tro...
How do I add/remove a DroneMobile unit from my account? ... (Do not start the engine, simply move the key to the final position before start); Immediately following the key ... Holding the button down will cause the remote programming to fail.
How do I program a remote to a Compustar system ...
https://support.compustar.com/.../202232840-How-do-I-program-a-rem...
How do I add/remove a DroneMobile unit from my account? ... Insert your vehicle keyinto the ignition and cycle the key to the 'ON' position and back ... Valet mode will be activated if the system does not identify a remote during programming.
Programing a Compustar 1Way 4 Button Remote - YouTube
Jan 12, 2016 | Vehicle Remote Starter and Security Kit
I have a compustar from-2w9000-ss remote and a button was pressed,locked me out ,what buttons do I press to get it to work again
PRIME 9000 1-Mile Range, 2-Way Select - Compustar
www.compustar.com/product/prime-9000/
Compustar1-Mile Range, 2-Way Model: RF-2W9000-SS ... The classic Compustar look that made us the top remote start brand in North America. ... The screen keeps you updated on whether your doors are locked and in the event of an alarm trigger, the ...
Compustar RF-2W9000-SS remote kit failure? - 8th Generation Honda ...
www.8thcivic.com > ... > ICE, Electrical, Security, & Navigation
Jan 8, 2015 - 4 posts
I have had my Compustar RF-2W9000-SS remote kit and secondary remote ... on my 2008 Honda Civic SI Coupe, FG2, at a compustar authorized dealer. ... my remote was not responding to my car (the unlock/lock, autostart, ...
CompuSTAR Starters - TheCarSalon.com
www.thecarsalon.com/home/automotive/remote-starters/compustar/
Either tap buttons I and III or Lock and Trunk simultaneously on your remote. ... The introduction of the RF-2W9000-SS in 2010 ushered in a new generation of .
RF-2W9000-SS by Compustar from Remotely Started MN
remotelystartedmn.com/product-details.php?product-id=40
Jan 07, 2016 | Cars & Trucks
The starter engages and starts the motor fine when the motor is cold. however if you ride and try to restart the starter just spins and you can only start using the kick stater.
"ATV" service and repair manuals - CRXSi.Com
www.crxsi.com/reference/manuals/atv/
.. arctic cat 400 4x4 engine · 04 arctic cat 4x4 400 4 wheeler manual trans startergears ... 2000 2x4 red atv artic cat repair manual · 2000 300 arctic 4 wheeler instructions .... 2007 arctic cat 90 c c four wheeler wiring diagrams · 2007 arctic cat 90four .... Atv Arctic Cat 2010 - Arctic Cat Dvx 300 And 300 Utility Service Manual ...
Aug 12, 2015 | Arctic Cat 2007 90 DVX 2x4
Manual transmission won't remote start even though Ive followed all the steps to leave it in reservation mode and car remains running until Ive exited and closed driver door. Error code is Sta
If your getting 7 flashes from a Compustar brain there is something not working right with the manual reservation mode. Double check to make sure it is 7. If it is then go see an authorized Compustar dealer and have them go over the installation and programming of the unit.
Nov 07, 2014 | 2-way Remote Transmitter - Dark Navy/gray
Arctic Start Compustar AR600S CS-600S Logo
375 people viewed this question
Top Arctic Start Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Arctic Start Health and Beauty Expert? Answer questions, earn points and help others
