Question about Lexmark Wheelwriter 1500 Typewriter
I can't get the reprint function to work. I printed out what I assume are the 2 key pages (the one that says how to reprint, and the page that shows how to load paper in the manner referred to on the paqe about the reprint function). I type something, I advance the paper using the return key (not an arrow key etc), I insert new paper following the instructions so as not to clear the reprint memory, I press the Reprint key... and nothing, on this WW1500. I don't know what to try next. I've replaced the batteries so any temporary settings I assume are now lost and I assume the default setting for the reprint key is to enable it. Thanks.
4 Suggested Answers
  • 3594 Answers
SOURCE: can't turn off re print
If you use the SAPI (semi automatic paper insertion) feature before you type the info you want to reprint the reprint memory will only have what you typed after SAPI.
You activate SAPI by pulling the rt. upper bail arm fully forward.
DickyO
Posted on Sep 15, 2008
  • 3594 Answers
SOURCE: IBM Wheelwriter 1000 wont Return everytime
Probably no cracking required. Spray a little WD40 on the silver shaft that the carrier slides on, if that dosen't do it there is the carrier motor in the left rear that the bearings dry up in a little WD40 will work there as well.
DickyO
Posted on Jul 09, 2009
SOURCE: How do I use the RePrint or Memory Function?
I have the 1500 model and know exactly what you are talking about. Look at this user guide, page 27. Hope this helps.
http://www.lexmark.com/publications/pdfs/2007/typewriters/Wheelwriter-1500.pdf
Posted on Oct 19, 2009
I have a Epson wf2540 printer and I want to copy only 1 page out of several how do I do that
This is a software function that is not controlled by the printer. If you need help with the printing function, you can use the F1 key to access help.
Place the page you want to print on the screen, then go to the print function. Look for something like 'Print current page", or if you have the page number, you can enter it in a 'print pages' box.
The printer will then print what you sent to it.
Feb 23, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
How do i reprint last thing printed
If you are using Linux, you can retrieve your old print jobs and reprint them easily. Go to localhost:631 in a web browser. From there, you can view your print jobs by clicking the Jobs tab at the top and then click on the Show All Jobs button.
This has proved very useful to me in the past, especially when printing a web page to my wireless printer, only to find out that the printer decided to not work properly and the webpage expired before I could reprint.
Aug 02, 2012 | Canon Office Equipment & Supplies
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
Can I reprint an incoming fax? I ran out of ink and the copies are unreadable? Pls tell me how to reprint a fax on my 6310 officejet.
If the printer doesn't have memory function itself... they're not going to reprint.
However, for your HP6310, they do have a function for 100 pages of fax memory.
Fo go fax manu (on your left side, by facing printer), press the fax set up and will see the reprint for fax.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 02, 2011 | Office Equipment & Supplies
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Printer reprinting the allready printed pages
Make sure that your document that u r printing's page size is set to A4!Good luck!
Apr 05, 2010 | Canon Office Equipment & Supplies
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Printing appears to reprint on other pages
I have seen several things fix a problems with reprint like yours depending on the spacing between the prints. There is a registration page in the service manual that points likely faults by the distance between reprints. This is based on the diameter of the failed part. Transfer roller, Print cartridge, and the fuser.
Apr 10, 2009 | HP LaserJet 2430tn Printer
IBM Wheelwriter 2 reprint feature
I assume you have a PERSONAL wheelwriter 2, if so it has a re prt key top l. of keyboard. Press the code and re prt keys and it will re print text.
DickyO
Jan 29, 2008 | Office Equipment & Supplies
Lexmark Wheelwriter 1500 Typewriter Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
