Question about Lasonic Audio Players & Recorders
LED Display is not working right
I just got my brand new Lasonic i931BTQ today. Tested every single one on it, and it works perfectly fine except for the LED display. The letters on the LED display is not showing up right. The letters are like some alien words that I can't understand at all. Is there any way to fix that?
  • 135 Answers
SOURCE: LED display is off
buy a new display?
Posted on Mar 31, 2007
SOURCE: Yamaha Receiver RX-V670
Parts list and exploded diagram of yamaha rx-v850 found free here:
https://www.vancebaldwin.com/shop/research_new/YAM/RXV850.pdf
Enjoy. They can get the bulbs for $1.40...
Bsmt Dweller
Posted on May 05, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Sharp 1505 Microwave Display Failure
There are two options for this model:
- You can order our exclusive modified control unit (CU150) with our proprietary upgrades for $95, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $40. Details are here.
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
We have the service manual for this model and have uploaded it to our site here to help you.
Repair service details are here.
Posted on Jan 18, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
Posted on Jun 15, 2009
SOURCE: brand new lasonic i931 boombox wont turn on!!!
okay, i had a similar problem, and the problem turned out to be a bad connection. If you open up the battery box, in the bottom top left corner there is a positive connection wire that looks kind of like a "U".
this connection doesn't come in contact with the batteries, so you need to extend it by wrapping a small piece of wire or something to make it stick out more.
what we actually did was put a piece of 1/4 in. by 1 in. piece of copper flashing in the plastic slot and across the U shaped connector to increase conductivity and it works fine.
i hope this was helpful!
Posted on Jul 01, 2009
Ignition coil distributor
adjust the gap to the minimum will solve the problem.
Dec 20, 2013 | 1999 Toyota Corolla
No dash lights when headlights are turned on. Everything works fine on my vehicle EXCEPT today the panel lights don't work. Turn signals, hazard blinker, oil gauge, rpm gauge, speedometer, drive shift...
there is a regulator for the display brightness, you may have it turn'd down or it has stopped working;. it controls the brightness at which the dash lights are. usually has a speedo sign on it. goes up and down. it works with the main light and is conecter to them on the same lighting board if it has gone then a new light swtch control switch will be needed.
Oct 13, 2013 | 2001 Chrysler Town & Country
Batt will not charge, i bought a new one and it not charge up either. plays dvd just fine what is going on?
That simply shows the fault is not from the battery.
Have you checked if the charger is working fine?, first check if the charger is working fine by testing it on another lasonic pdl305 portable dvd player to see if it is working.
If it does not work then you have to replace the charger.
The next thing to check is the charging port, to test this, try to use a tested ok charger on it to see if it works.
If it does not, then you can tell it is the charging port that has a problem. All you have to do is replace the charging port.
That is How you detect the fault and fix it.
Take care
Jun 15, 2010 | Lasonic PDL-305 Portable DVD Player
Worked fine yesterday - will not turn on today - kitchen
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Feb 07, 2010 | IBM ThinkPad T40 2373 Notebook
Problem with Lasonic i pod ghetto blaster
Happened to me, and a very common problem. on the top left of the battery compartment, there is a U shaped connector meant to hook up with the + battery on that side. it's too low, so the circuit doesnt complete. Use some aluminum foil or copper wire to make the U connect with that battery and it should work.
Jun 16, 2009 | Lasonic Ghetto Blaster i931 Boombox
Brand new lasonic i931 boombox wont turn on!!!
Jun 10, 2009 | Lasonic Ghetto Blaster i931 Boombox
RCA RTD315W Receiver/DVD LED display
If you are referring to the information display, it doesn't activate until you take the system out of standby (the bright blue LED at the corner is shining). When you hit the OFF button (on the system or the remote) and the blue LED shuts off, your info display comes on and says WELCOME.
Dec 27, 2008 | RCA RT2500 System
The player does not recognize the hard disk after converting to NTFS.
check and see if the harddrive settings are set to master. this will solve the problem
Nov 07, 2006 | Lasonic HV-670
46 people viewed this question
Top Lasonic Audio Players & Recorders Experts
Jonathon summesfield
stynger007
Level 1 Expert
Joseph Hoffmann
Are you a Lasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
